Thread: Weird brake issues
Results 1 to 4 of 4
  1. #1 Weird brake issues
    Apr 2011
    North Los Angeles
    So I'm driving to work this morning stop for coffee and as I'm pulling away from 711 i get the traction light. At first i thought i accidentally pushed it off but i push it and reset and alert goes away.
    A few hundred yards down the road i hear a weird buzzing humming sound (used to hear it all the time before replacing bearings) i hit the brakes and they feel locked,it makes this humming sound even louder and the brake pedal is stiff,little to no reaction and i have to slam on the pedal to get it for stop, all while making a nasty grinding noise like something is in between pads and rotor.
    I pulled to the side and pumped brakes a few times checked for any leaks and to see i had enough brake fluid,nothing out of order. The remaining drive was perfect, has anything like this happened to anyone?
  2. #2 Re: Weird brake issues
    GTP Level Member
    Oct 2014
    You have an ABS problem. Bad hub, bad wire to a hub, or module on the way out.
    Time to read the codes it stored.
  3. #3 Re: Weird brake issues
    Apr 2011
    North Los Angeles
    Hmm im thinking module perhaps ive replacednboth hubs recently
  4. #4 Re: Weird brake issues
    SWPA
    Rear hub can cause ABS issues as well.
  1. Couple weird issues
    By al2000gtp in forum General Grand Prix Discussion
    Last Post: 10-19-2012, 07:54 PM
  2. Ok weird issues.
    By Bluemagic in forum General Tech Discussion
    Last Post: 08-12-2012, 12:46 PM
  3. Weird Drivability issues
    By Digity in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-24-2011, 09:23 AM
  4. Weird Electrical Issues
    By tdm571 in forum General Tech Discussion
    Last Post: 03-15-2011, 09:34 AM
  5. Weird starter issues, help pls?
    By gdbyrd in forum General Tech Discussion
    Last Post: 04-28-2009, 09:04 AM
