Thread: ZZP garlock gasket?
Results 1 to 20 of 32
  1. #1 ZZP garlock gasket?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    So I read a thread on here about not to use zzp's garlock gasket well zzp set me up with one about a year ago are they really that bad? How will I know if it's leaking?
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #2 Re: ZZP garlock gasket?
    Buffalo
    I use them and I also use them with rtv
  3. #3 Re: ZZP garlock gasket?
    Kemmerer, Wyoming
    which gasket are you talking about?
  4. #4 Re: ZZP garlock gasket?
    Jul 2015
    Jamestown, NY
    Supercharger gasket
  5. #5 Re: ZZP garlock gasket?
    Kemmerer, Wyoming
    I'd run it. you will know it's leaking either because you have a vacuum leak or there is coolant pooling in the lim crevices.
  6. #6 Re: ZZP garlock gasket?
    Jul 2015
    Jamestown, NY
    I have my coolant holes welded shUT so I'd just have a vacuum leak? So it wouldn't idle right correct? Whats the vacuum supposed to be at anyways?
  7. #7 Re: ZZP garlock gasket?
    Jul 2015
    Jamestown, NY
    Ya know the more I think about it this has been bothering me what is the teaspoon of oil that leaks in the LIM crevice? Its where the LIM bolt goes in one spot in the front and back literally just a teaspoon. It's done it when I first bought the car, when it was completely built N/A and when it's supercharged I dont get it.
  8. #8 Re: ZZP garlock gasket?
    take that bolt out, rtv the threads, put it back in, no more leak. mine also leaked at one time. rtv fixed it up.
    id take them garleaks and toss em in the trash.
    you can get a paper gasket for both gen 3 and 5, not sure what your running. or rtv the blower on.
  9. #9 Re: ZZP garlock gasket?
    Jul 2015
    Jamestown, NY
    Okay I did rtv the threads when I installed it must not have been enough. As far as the garlock gasket I'd know if it was leaking though right?
  10. #10 Re: ZZP garlock gasket?
    Buffalo
    I run garlocs ONLY because I have an intercooler and they NEVER leaked. But I also don't install them dry. I use right-stuff rtv as well
  11. #11 Re: ZZP garlock gasket?
    Jul 2015
    Jamestown, NY
    Yea I don't understand why people use a gasket and rtv that's what the gasket is for zzp said use it dry it's a gasket I don't know unless I have problems I'm not going to take the blower off. It's two completely clean and flat surfaces I don't understand how it'd leak anyways.
  12. #12 Re: ZZP garlock gasket?
    spray carb cleaner at the gasket. if its leaking the idle will go up.
    if it was leaking enough you would get a lean code, or have a higher or surging idle.
  13. #13 Re: ZZP garlock gasket?
    Buffalo
    Quote Originally Posted by Tonkin2000GT View Post
    Because it's pre cut for intercoolers and the rtv is insurance so it doesn't leak? C'mon man lol
    yes you can use it dry too. But I do things up and beyond so I don't have issues
  14. #14 Re: ZZP garlock gasket?
    Buffalo
    Or try propane from a hand held torch. That way your engine bay isn't getting destroyed (if it's nicely painted)
  15. #15 Re: ZZP garlock gasket?
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by CrazyGuy03 View Post
    Yeahh cuz that's what I'm going to do NO but for the reference I never asked for your opinion.... If you don't have anything nice to say don't comment on my **** alright? I've seen several comments on my own posts and other people's posts by you that are arrogant it's ridiculous.
  16. #16 Re: ZZP garlock gasket?
    wow. why all the hostility?
  17. #17 Re: ZZP garlock gasket?
    Jul 2015
    Jamestown, NY
    I don't know ask crazyguy03 I'm simply asking for advice because I haven't done it yet or have an issue with something and he talks to you like your retarded... and I'm not the only one kinda over it don't comment on my posts...
  18. #18 Re: ZZP garlock gasket?
    i saw nothing of the sort in his post. hes sharing how he does it. hes also done it more than one time.
    i used nothing but rtv on my ic. been just fine so far. the garlocks do have a horrible rep for leaks, unless you rtv them.
  19. #19 Re: ZZP garlock gasket?
    Jul 2015
    Jamestown, NY
    This Scotty irritated me C'money man lol? But that's not the main reason if you go to the tranny section and read my thread on shift kits he's commenting saying this thread hurts my head and crap like dude seriously? Mess with someone else I was asking serious questions I don't need your bs. Like I said though I've seen him be arrogant to several people on the forum it's not hard to tell... what he needs to realize is some people really don't know hence the reason they are asking.
  20. #20 Re: ZZP garlock gasket?
    likely its a all to common question, or the thread went off line, idk..... i see no issue with his posts. theres far worse here, thats for damn sure....vet will show up tell you how he feels sooner or later as its a ic thread lol
  1. Head gasket problem, 25 miles on new gasket
    By GTPlzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2014, 04:25 PM
  2. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  3. garlock?
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 08-06-2010, 12:21 PM
