Thread: garlock?
Results 1 to 6 of 6
  1. #1 garlock?
    Joliet, IL
    are garlock gaskets better than oem? never heard anything about them.....thinking of scooping up the one in the FS section so wanted some insight b4 hand.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: garlock?
    Akron Ohio
    I was told that they where no good. Just go to the Dealer there not that much for a better part.
  3. #3 Re: garlock?
    Portland Oregon
    I saw the one you're interested in. FWIW if you have a gen V, the OEM gasket is better. Also, garlock likes to soak up any fluids or oils. They do seal well though on a good smooth surface.
  4. #4 Re: garlock?
    i couldnt get a garlock to seal for ****. i put an OEM gasket in and it sealed 100% the first time.
  5. #5 Re: garlock?
    Feb 2008
    Go make one out of a thin sheet of silicone. It'll cost you about $10 and you can re-use it multiple times.
  6. #6 Re: garlock?
    Charles City, IA
    Use a stock gasket.
    SMGPFC Two Nipple General
