Thread: Car really messed up at this point. Oil loss and now sounds like bearing or rod knock
Results 1 to 20 of 24
  1. #1 Car really messed up at this point. Oil loss and now sounds like bearing or rod knock
    GT Level Member mainecrab's Avatar
    Feb 2008
    Looks like when I changed the oil last on the car the gasket either had a failure or something as oil spewed up and all over the engine compartment leaving a trail down the street and when wife finally got the car home. Didn't go far at all down the road, it was about empty and now after changing the filter and PCV valve since it was clogged it now runs but has a knock that gets louder as the engine RPMs go up.
    Sadly I found a good car to buy before this happened but backed out since was thinking I need to save money instead of have another monthly payment, sigh.
    So is there anything I can do other than pull the oil pan and replace whatever is bad? Any higher weight oil or some magic in a bottle that may help fill any gap? I assume the bearing got scored or something with the oil pressure loss.
    Comes at the worst time ever. After having a new baby and having to pay for about 6K in hospital bills and now car is fubar.
  2. #2 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    It's machine shop bound if you really want to replace anything.
    Better off swapping another motor in.
  3. #3 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    Feb 2008
    Sounds like I have to take a loss and just sell the car for whatever I can get for it. I cannot change an engine myself and have no guy friends to help out if I could get a new motor to swap in.
  4. #4 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    Feb 2008
    So car will be parted some and the rest sold. Bought a 2014 Impala so my life with this Gravd Prix is about over. Was a good 8 years and could of gone many more I'm sure.
  5. #5 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    Oct 2014
    portland oregon
    Rip gp
  6. #6 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    May 2008
    Schuyler, NE
    Where are you from?
  7. #7 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    Feb 2008
    Houston Texas
  8. #8 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    GXP Level Member
    Mar 2015
    Tomball
    Well you don't have to go far for an engine you can't throw a rock without hitting something with a 3.8 supercharged or N/A.
    Jeff
  9. #9 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    May 2012
    Where winter never ends
    Honestly an engine is an easy job. There are guides on how to pull it safe and quick here, a motor would be cheap. Way cheaper than a new car.
    2000 Regal - Winter Beater
  10. #10 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    Feb 2008
    Well I already got the car and its used but was a great deal and still under factory warranty. I had a new baby and kind of hard to do much else or take on a engine swap alone. While it would be alot cheaper its just not feasible right now.
  11. #11 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    May 2012
    Really only takes 2-4 hours if you go fast and have the tools but yeah I guess scrap it then lol
  12. #12 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    GXP Level Member
    Mar 2015
    Tomball
    What part of Houston are you on?
  13. #13 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    Feb 2008
    Northside
  14. #14 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    Feb 2013
    37.295091, -121.930053
    looks like someone wants to help ya out with it
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  15. #15 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    GXP Level Member
    Mar 2015
    Tomball
    I am near Spring Branch for work and Drive out to Tomball where I live.
    Jeff
  16. #16 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    Enfield, CT
    is the car completely stock or do you have any mods?
  17. #17 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    Feb 2008
    Well it wouldn't be anytime soon I'd be working on it. It will get lower priority at this time. So I may end up keeping it and working on it. Not sure yet. It's stock besides a DHP PCM. I don't have room for a engine lift and place to put the old and a new engine. Though yeah I do appreciate any help I can get.
  18. #18 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Quote Originally Posted by mainecrab View Post
    Houston Texas
    Based on your screenname I assumed you were a long way from here. I am usually pretty busy, but if a weekend of wrenching was organized, I could prob help out for a bit. Where on the northside are you? 45 & BW8, Spring, Woodlands?
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  19. #19 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    GXP Level Member
    Mar 2015
    Tomball
    Lol, I thought the same thing.
  20. #20 Re: Car really messed up at this point. Oil loss and now sounds like bearing or rod k
    Feb 2008
    45N and 1960
  1. Sounds like a wheel bearing, but I'm not sure...
    By Booba5185 in forum Brakes/Suspension/Chassis
    Last Post: 06-15-2017, 11:49 PM
  2. Did my wheel bearing/hub got messed up?? after removing and replacing
    By Haulero in forum General Grand Prix Discussion
    Last Post: 06-10-2012, 03:25 PM
  3. messed up engine
    By 1998 problem child in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-11-2011, 02:11 AM
  4. New PCM? I messed up!
    By Workshop in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-22-2011, 06:42 AM
  5. Seems kinda messed up huh?
    By real diehl in forum Off Topic Discussion
    Last Post: 07-25-2010, 12:42 AM
