Thread: Some more top swap questions! Yay!
Page 64 of 71 FirstFirst ... 14546263646566 ... LastLast
Results 1,261 to 1,280 of 1411
  1. #1261 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Ok once i get on the computer ill upload the current bin. Also is just the bottom row of the timing table considered wot?
    Sent from my LG-D851 using Tapatalk
  2. #1262 Re: Some more top swap questions! Yay!
    what i highlighted is your wot timing cells.
    and the dhp scanner dont work unless you hooked up to the car, hit scanner, then pic what you want to scan then check off a few gauges of things you want to see live while you scan.
    same for the uvscan, needs to be plugged in to work at all.
  3. #1263 Re: Some more top swap questions! Yay!
    Oct 2015
    Okay scotty!! Here is a link to the current bin https://www.dropbox.com/s/aw0rnxxgsq...0tune.bin?dl=0
  4. #1264 Re: Some more top swap questions! Yay!
    shoot me your email, ill email that bin back to you, your timing looked like n/a timing, i put topswap files in there, its a degree lower then stock gtp timing.
  5. #1265 Re: Some more top swap questions! Yay!
    Oct 2015
    See i thought they looked a little high considering its a topswap i thought if anythinh the timing should be stock gtp timing ir maybe even slightly lower
  6. #1266 Re: Some more top swap questions! Yay!
    pm me your email, my drop box is to full to take another thing lol i can email it back to you and you can flash it back, night and day difference will be felt.
  7. #1267 Re: Some more top swap questions! Yay!
    Oct 2015
    Its Suitercrew@gmail.com
  8. #1268 Re: Some more top swap questions! Yay!
    sent tuner rev too. enjoy
  9. #1269 Re: Some more top swap questions! Yay!
    Oct 2015
    I took a quick scan on my way to the store just to test out the process and it wouldnt save. It got stuck on the last bar
  10. #1270 Re: Some more top swap questions! Yay!
    Stop driving till you flash that new bin.
  11. #1271 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok scotty im about to flash it the only question i have is does this bin have the 3.29 gears?
  12. #1272 Re: Some more top swap questions! Yay!
    i sent you back your bin with what ever gears were already in there. all i did was fix the timing.
  13. #1273 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    how much timing did he end up with after your adjustment?
  14. #1274 Re: Some more top swap questions! Yay!
    it was n/a timing, so a lot. how it didnt blow up i dont know. funny cause its a gtp bin file. i think brian had a cluster f moment. maybe he was doing 2 things at once? idk, but mistakes can happen.
    if the tranny was not set up right chances are he would have felt that already. ill take a look at it tho for the hell of it.
  15. #1275 Re: Some more top swap questions! Yay!
    Quote Originally Posted by SgtMarshal View Post
    now hes set up with one degree lower wot timing vs a gtp file. he should hit 15ยบ now.
  16. #1276 Re: Some more top swap questions! Yay!
    thrans files were changed and tuned. i did go and check the timing again, i thought i took it from a bin with the lower timing, ( that ones on my lap top i guess) its at stock gtp timing now. if need be he can lower it easy enough.
  17. #1277 Re: Some more top swap questions! Yay!
    Oct 2015
    Ya i took your tune and drove around till the ft locked on and then i drove it for a scan and im getting about 2 degrees of kr at wot now. I have fully switched back to only 91 octane. So ya ill have to pull some more timing. But it is a lot better then 4 , 4.5 degrees of kr lol
  18. #1278 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    it's a miracle. I can't believe it didn't blow up. dont they have like 25* of advance na?
    maybe pull 1-2 more degrees of timing since there is still a small amount of kr.
  19. #1279 Re: Some more top swap questions! Yay!
    what was your wot timing on the scan?
    its got to feel a load faster/stronger now for sure.
    if you want ill lower it 2 degrees for ya and email it back.
    if you go to export logs, where the scanner is in dhp, you can export it, save as a csv file, name it todays date, then e mail it to me, so i can see the scan.
  20. #1280 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    when I take a scan, I use the time and date when the scan was saved.
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
