Quote Originally Posted by suitercrew View Post
Hey scotty did you see the posts about the l67 hb i pulled off with my hands? Tonkin said i probably shouldnt use it if it was that loose. Your opinion?
Sent from my LG-D851 using Tapatalk
probably not. if you mean you took the bolt out, then literally pulled it off bare handed. the last 1/2 or so they slide off and back on easy then line up the key way by turning it till it drops another 1/2 inch deeper on the crank.
