Thread: Some more top swap questions! Yay!
Results 1 to 20 of 1411
  1. #1 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey scotty did you see the posts about the l67 hb i pulled off with my hands? Tonkin said i probably shouldnt use it if it was that loose. Your opinion?
    Sent from my LG-D851 using Tapatalk
  2. #2 Re: Some more top swap questions! Yay!
    Quote Originally Posted by suitercrew View Post
    probably not. if you mean you took the bolt out, then literally pulled it off bare handed. the last 1/2 or so they slide off and back on easy then line up the key way by turning it till it drops another 1/2 inch deeper on the crank.
  3. #3 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    My orginal NA pulley I took off it was pretty on there tight all the way off with the puller. Then when I put my SFI crank pulley on it didn't slide over the crank by hand at all I lined it up put the bolt in and slowly started it by impacting the bolt but it was new.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
