Okayy so i have a problem i have the tensioner and the coil bracket but thats it. Am i missing a part? That metal bracket right under the wayer pump inlet i dont have
Sent from my LG-D851 using Tapatalk
Ok im sorry scotty i hope im not driving you insane but this is just really confusing for me. So if im understanding right the two bolt holes on the top of the coil bracket are where the studs slide in then the tensioner goes on the inside stud then gets bolted down. The bottom outside bolt hole is for another pulley that just gets bolted down and then from there i have no idea especially with the #9 pulley i. The picture
this is the best pi i have. i used to have two studs, now only one. and i used a bolt on the lower hole.
the tensioner needs a thin walled 13 mm deep socket. a 12 point socket seems to fit best.
the missing idler pulley you need the bolt for it too, it goes into the bracket on that bottom part thats sticking up.
you can see how the tensioner should look too.
pulley bolts all come off, they all bolt into something, pulley spins free all the time on a bearing. all bolts are normal threads too, not reverse threads.
Yeah well i dont have it but i figured tomorows my day off im just going to run around town looking for some l67 that arent totally destroyed and that way i can see it and grab what i need in person
So the last question i have is the pulley that is underneath the water pump and tensioner how does it bolt to the block cause its not on the coil brack or heads?
