Re: Some more top swap questions! Yay!
Ok great! I just want to say thanks to all you guys for your help i would never even be able to attempt doing this if it wasnt for everyone here!
Sent from my LG-D851 using Tapatalk
ScottyDoggs
not sure they are the same bolts. the na bolts look much thinner. get bolts form a junk yard sc.
if you sent bolts with the lim, those are the ones I'm using on my supercharged lim. I don't remember if you did or not.
i did send them with the na set up, hard to believe they fit lol
ScottyDoggs
maybe that was a factor in all the extra work
idk, they just seemed to be a thinner shaft bolt to me. the bolt head is smaller too iirc.
ScottyDoggs
bolt head is still 10mm, and they have to be the same threads because of the heads. only thing that might be different is the length.
sc bolts only go in the lim.
the lim bolts are the same.
ScottyDoggs
that's what I thought we were talking about
lim or sc?
i sent no lim bolts. just the upper intake to lim bolts
ScottyDoggs
lim or sc?
lim to heads is what I thought we were talking about, the upper intake manifold bolts are 5/16, except 1 which was a 10mm.
Ya i have the bolts for the sc to the lim but not for the lim to the heads.
re use your lim bolts, they are the same.
Great!
suitercrew
the bolts that bolt the lim to the heads are the same on supercharged car's as on na cars
Whats the best way to clean off the old gaskets off supercharger and lim. Last time i used tb cleaner but it took forever!!
parts cleaner and a razor blade, unless you have an aircompressor and right angle gasket grinder
razor blade scrapper. or them rotary cleaning disks.
Ok thanks!
Hey so im cleaning my m90 up and didnt plan on doing anything fancy with it but i found some caliper paint i had laying around so would it be ok to paint it with that?
I'd just spend the $7 and grab some engine enamel.. Caliper paint seems to come out to thick (well with my experience with it)
