Thread: Some more top swap questions! Yay!
Page 49 of 71 FirstFirst ... 39474849505159 ... LastLast
Results 961 to 980 of 1411
  1. #961 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    If you look up m90 supercharger rattles noise in youtube thats what it sounds like
    Sent from my LG-D851 using Tapatalk
  2. #962 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    If your state doesn't have strict emissions, I would just take the evap purge solenoid off and suitable all the fail codes. It does look real clean.
  3. #963 Re: Some more top swap questions! Yay!
    Oct 2015
    Im in az and they do have strict emissions. A bent egr tube wouldnt cause this problem would it?
  4. #964 Re: Some more top swap questions! Yay!
    Quote Originally Posted by suitercrew View Post
    Ok ill think it over and probably get one if the dhp in the classifieds and just borrow someones laptop. On a side note though i just took it for another spin cause i had the evap selonoid plugged in backwards which didnt really do anything but when i pulled up back home the sc was making even more noise then it was earelier for no apparent reason
    theres a thread with tablets that work with the tuners. if you got one of them hanging around.
  5. #965 Re: Some more top swap questions! Yay!
    it could if its leaking. now with a tuner you can get rid of it. inspection dont know jack, it shows ready in system, all they care about.
  6. #966 Re: Some more top swap questions! Yay!
    Oct 2015
    But we have visual inspection
  7. #967 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    If the egr tube is bent and cracked it would cause your fuel rims to run lean and make some kr
  8. #968 Re: Some more top swap questions! Yay!
    like they pop everyones hood and look for things? you could also block the egr off and leave it in place as a dummy part, aka just for looks.
  9. #969 Re: Some more top swap questions! Yay!
    Oct 2015
    How would i go about blocking it off scotty?
  10. #970 Re: Some more top swap questions! Yay!
    you can cut the egr hose off so you can get the tab that bolts to the lim and rear header, then rtv a coin under the tab and bolt its back on, dummy the egr back on so it looks like its working.
    you can also use some 1 inch wide flat stock, cut to length then drill a hole for the bolt. smear some rtv to seal the plate around the holes.
  11. #971 Re: Some more top swap questions! Yay!
    this is a egr tab and a coin bolted on place same for the header.
  12. #972 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok i have an extra egr tube so ill probably just do the first one. Also i had an idea if i was getting kr because it was running to rich then couldnt i unplug the front o2 which hypothetically would force a rich condtion and then i could scan and see if i was still getting kr?
  13. #973 Re: Some more top swap questions! Yay!
    extra egr tube good,
    the rest of that post,,,,no.
    once the trims learn you'll know if your lean or rich wot or not.
  14. #974 Re: Some more top swap questions! Yay!
    Oct 2015
    Lol aww i thought that was a really good idea but ok thanks scotty
  15. #975 Re: Some more top swap questions! Yay!
    Oct 2015
    O scotty btw im getting really bad gas mileage about 12.5 mpg city compared to my usual 17.5 when i was na. I dont really care but maybe this could help pinpoint the problem?
  16. #976 Re: Some more top swap questions! Yay!
    dont think so, it maybe lower cause your foot makes it make cool sounds now?
  17. #977 Re: Some more top swap questions! Yay!
    Oct 2015
    Lol ya well it doesnt sound that cool when i cant go over 50% throttle
  18. #978 Re: Some more top swap questions! Yay!
    Oct 2015
    How would i check for a exaust leak assuming that would cause the kr issue? I cant hear anything atleast like when it didnt hace the front o2 in it lol
  19. #979 Re: Some more top swap questions! Yay!
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Put a rag over the 2 exhaust pipes. Any exhaust leaks will become more present. Have someone cover the pipes, and you listen.
  20. #980 Re: Some more top swap questions! Yay!
    smear rtv on the egr tube thats dented, it will seal up a leak if you have one there.
    if you got an exhaust leak you'll hear it.
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
