Thread: Some more top swap questions! Yay!
Page 19 of 71 FirstFirst ... 917181920212969 ... LastLast
Results 361 to 380 of 1411
  1. #1 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by suitercrew View Post
    Ok so i dont need the by pass solenoid correct just leave the actuator open to atmosphere. Also do you know what size vacc lines ill need?
    Sent from my LG-D851 using Tapatalk
    Correct that's full boost. I just got my lines at advamced auto parts I believe 7/32 and 5/32 fit well I remember having to use two different sizes and get a union because the map sensor nipped is bigger then the fpr
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #2 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    This might sound dumb but whats a union?
  3. #3 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    I meant like a plastic T connector to hook the fpr and map sensor to the LIM nipple I was able to find a T connector that fit my 5/32" hose to my fpr and my 7/32" map hose together then hooked them to the LIM I think the T connector was like 3/16" it's been a while though just go to the parts store test fit things for sizing.
  4. #4 Re: Some more top swap questions! Yay!
    Oct 2015
    For sure thanks for the help would the vac line from the bbv and the tree probably be 7/32 too then?
  5. #5 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Yupp if you need a picture of mine I can send you one
  6. #6 Re: Some more top swap questions! Yay!
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    You can either run the wiring from the ECM to the solenoid to allow the PCM to control boost (kills boost in reverse and traction control) or program traction control off. Also if you are running the SD headers without a cat the rear O2 is pointless. It will just set a code. Needs to be programmed off. (Or buy an EBay cat and weld or clamp in and use the spark plug non-fouler trick)
  7. #7 Re: Some more top swap questions! Yay!
    Oct 2015
    So if i dont program tc off what happens to boost
  8. #8 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    if you car is like mine, if your traction control is off then you won't lose boost. I'm not sure what changes I have in my tune for traction control. if you don't turn off your traction control, then the engine will cut boost and power. I have a button I push to turn off the TC.
  9. #9 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok i have that button to so as long as it turn it off everytime i start the car im golden!
  10. #10 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    sometimes I forgot to turn mine off, and the car bogs down when I floor the gas pedal.
  11. #11 Re: Some more top swap questions! Yay!
    Oct 2015
    Thats such a weird design i dont understand why anyone would make that like that
  12. #12 Re: Some more top swap questions! Yay!
    Jul 2014
    Toledo, OH
    TC defaults to on when the car is started for safety reasons. When wheel slip is detected boost is released, timing is pulled, and fuel cut to reduce engine power. I don't know the algorithm as to what is first, the aggressiveness, etc. I would think if the ECM is commanding the boost control solenoid to open to actuate the valve and it doesn't see a reduction in boost, it would think the bcs is malfunctioning and set a code. That is only my guess. I am still N/A till I do my top swap when it gets warmer. You can program the ECM to default to TC off so you don't have to push the button each time. If I had the time and software I would reverse engineer the TC and make it more performance based and less nanny.
  13. #13 Re: Some more top swap questions! Yay!
    Oct 2015
    You should do that and then send me a bin lol
  14. #14 Re: Some more top swap questions! Yay!
    its super easy to turn of tc in the tune. just ask for it in your tune.
  15. #15 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok!!
  16. #16 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    I just bought zzp's traction control thing it's a couple wires you hook up to the traction control button harness in your dash it was really easy. So basically when you start the car traction control is always off if you want it on just press the button.
  17. #17 Re: Some more top swap questions! Yay!
    Oct 2015
    Hmm well ill look into both i guess i would always like to have the ability to turn it back on if i was on really wet ore icy roads
  18. #18 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Yea what I did because I was sick of the traction control off light being on when you start it I just pulled the bulb.
  19. #19 Re: Some more top swap questions! Yay!
    when my abs worked, lol tc got turned off if the roads were wet at all. nothing like pulling out in traffic and the engine falling on its face and getting t boned.
    my car would hardly move in snow too with tc on, its worthless and is of no help to me at all. turn it off, add wheel spin car moves like magic all of a sudden.
  20. #20 Re: Some more top swap questions! Yay!
    Oct 2015
    Are all aeroforce gauges the same i found a guy selling an aeroforce a aem wideban and a phantom 2 boost gauge for 200$ is this a good deal?
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
