Thread: SLP header question
Results 1 to 20 of 23
  1. #1 SLP header question
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    I just bought a used set of SLP headers for my 2000 Grand Prix GT. I haven't got them yet but wanted to know what I need so I can order it does anyone know if you need an o2 extension wire? The car is a GT but I top swapped so it has the GT wire harness if that makes a difference in length.
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #2 Re: SLP header question
    I think the o2 bung is in the crossover on those, but don't quote me on that. If it is, then you do not need the o2 extension.
    Factory header/manifold gaskets are metal, so re-use those as they are the best.
    Other than that I can't think of anything, they should bolt up just fine.
  3. #3 Re: SLP header question
    Jul 2015
    Jamestown, NY
    I just looked on the 3800 performance website and the o2 bung is right before the flex pipe. I read there description and in small print it says o2 extension included in the install kit just not in the pic. Do you know where I can get one besides zzp?
  4. #4 Re: SLP header question
    Bung is right befor the flex for sure.
    Tough to tell you what you'll need if we don't know what's coming with them. Often sellers will include clamps and extensions etc.
  5. #5 Re: SLP header question
    Jul 2015
    Jamestown, NY
    It doesn't come with an o2 extension that's all I was wondering I have everything else. Does anyone have one they want to sell?
  6. #6 Re: SLP header question
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    caspers electronics has them. I used to have one lying around. I wish i could find it.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  7. #7 Re: SLP header question
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by BoostedPontiac View Post
    That'd be nice I'd buy it right now lol.
  8. #8 Re: SLP header question
    ZZP sells them too, only like 15 bucks.
    Doesnt really matter where you get it from, still going take 2-3 days to ship one to you.
  9. #9 Re: SLP header question
    Jul 2015
    Jamestown, NY
    Yea I know I could careless to give zzp another penny after the last transaction they screwed me on. I can't seem to find them at caspers electronics though.
  10. #10 Re: SLP header question
    you can cut the plug off the cars harness, then add 3 foot of wire to it, via solder and shrink tubes. then run the plug to the strut town and down to the rack then to the o2 so its got no chance of melting on the header.
  11. #11 Re: SLP header question
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by ScottyDoggs View Post
    Yea I honestly thought about doing that I solder all the time about 3 feet to route it better your saying? Even if I buy the harness extension it should be longer is what your saying?
  12. #12 Re: SLP header question
    that harness they sell could be longer. lots of times they melt on the header.
    this is mine, i got brake lines and crap to zip tie it to, but it dropped to the rack, then followed the rack to the o2 sensor. free and clear of the header pipes 100%.
  13. #13 Re: SLP header question
    Jul 2015
    Jamestown, NY
    Okay thanks man. Yea I have a strut tower brace I can secure it to I thought about just extending the wires on the o2 sensor so I can just do it on the work bench. Do you know what gauge wire I need? If I just add 3 ft I'll be good? I was going to do it before I install the headers is why I ask.
  14. #14 Re: SLP header question
    the o2 wires to its plug, one is stainless steel, its a ground, solder wont take to it.
    the cars harness, all the wires are copper.
    best to extend it from the cars harness.
    i got a 10 foot roll of wire cut it into 3 equal parts. i forget what gauge it was. iirc its 3 wires lol its been a while.
  15. #15 Re: SLP header question
    Jul 2015
    Jamestown, NY
    Okay thanks for the info
  16. #16 Re: SLP header question
    Jul 2015
    Jamestown, NY
    Hey Scott I was wondering do you use rtv on the exhaust manifold gaskets? Or just use them how they are? I'm using some felpro gaskets.
  17. #17 Re: SLP header question
    return them gaskets. re use the stock metal ones on the car now. they are the best gasket to use.
    i used no rtv on any part of my headers. i also used band clamps on the cross over pipe. them U clamps are horrible. if thats what you planned on using.
  18. #18 Re: SLP header question
    Jul 2015
    Jamestown, NY
    I don't have the stock ones they weren't on the car when I bought it. Can you buy them?
  19. #19 Re: SLP header question
    im sure you can, maybe a dealer only item, or maybe rockauto will have em.
    are the felpro's fat gaskets? or thin metal?
    this is what a stock one looks like.
    with a side dish of port work whoring.
  20. #20 Re: SLP header question
    Jul 2015
    Jamestown, NY
    They are gasket material with metal rings around the exhaust ports. Are the stock ones way better? Worth getting? Also I talked to a couple guys everyone has there opinion but when the machine shop ported my heads he basically gasket matched the exhaust ports took alot out I'd send you a picture but I don't know why it won't work.
  1. Header question.
    By acidronin in forum General Grand Prix Discussion
    Last Post: 09-19-2014, 04:40 PM
  2. header question
    By joe0813 in forum General Tech Discussion
    Last Post: 11-01-2012, 04:07 PM
  3. Header question
    By Logan541 in forum General Tech Discussion
    Last Post: 11-12-2011, 07:37 PM
  4. sd header question
    By m17davis in forum General Tech Discussion
    Last Post: 02-10-2011, 11:28 PM
  5. header question
    By 06grandprix93 in forum General Tech Discussion
    Last Post: 03-06-2010, 09:39 AM
