Thread: Header question.
Results 1 to 8 of 8
  1. #1 Header question.
    Sep 2014
    I was trolling around ebay yesterday and found an auto salvage yard parting out a 2000 gtp. They listed a set of pacesetter headers as stock manifolds for 100$ shipped.
    I immediately jumped on it.
    Afterwards I noticed it doesn't have the flex/downpipe. So basically it ends at the y pipe.
    Did I get a good deal? Can I have an exhaust shop fab something up?
  2. #2 Re: Header question.
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    You could get a shop to do that.
    I believe zzp down pipe will hook up to them.
    Someone correct me if I'm wrong though
  3. #3 Re: Header question.
    from the pics i see on line it looks like a 3 bolt flange. so any shop can make you a dp and weld in a cat if you need one.
  4. #4 Re: Header question.
    No ZZP DP will bolt up to a Pacesetter downpipen except for a Pacesetter downpipe.
    Just buy cheapo Speed daddy headers off EBay.
    Done and done.
  5. #5 Re: Header question.
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Orr.... just buy a 3 bolt flange, zzp flex and a 2 bolt 2.5inch flange for the stock catback, exhaust shop could weld you together a pacesetter DP for like 30-40 plus the stuff I listed.
    04 GTP -HAI, 1.9 rockers.
  6. #6 Re: Header question.
    Aug 2013
    Sandy, UT
    Or buy a cheap welder and learn :-)
  7. #7 Re: Header question.
    Sep 2014
    Sounds good to me. Thanks
  8. #8 Re: Header question.
    Aug 2013
    Sandy, UT
    Yeah. Shop local to me made a weld in downpipe section for my RWD 3800 pacesetters for 20$, but that was just 2 welds. Should be in that price range and you'll have some used pacesetters for about 200ish. Not a super deal but not a bad deal either... As long as they don't leak.
  1. header question
    By joe0813 in forum General Tech Discussion
    Last Post: 11-01-2012, 04:07 PM
  2. Header question
    By Logan541 in forum General Tech Discussion
    Last Post: 11-12-2011, 07:37 PM
  3. sd header question
    By m17davis in forum General Tech Discussion
    Last Post: 02-10-2011, 11:28 PM
  4. header question
    By 06grandprix93 in forum General Tech Discussion
    Last Post: 03-06-2010, 09:39 AM
  5. TOG Header Question...
    By Iron Indian in forum General Tech Discussion
    Last Post: 01-09-2008, 01:00 AM
