BillBoost37
If it starts and stalls. That means the pcm is allowing it to get the prime that happens with key on and then is not allowing more fuel. This is typically either the fuel pump resistor or a security issue.
You mentioned trying both keys, did you confirm that the light on the dash is not still complaining? The ring that does whatever it does to the keys do go bad. If that's the case.. it wouldn't matter how many keys you tried.
