Thread: Downshifting an automatic trans
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 93
  1. #41 Re: Downshifting an automatic trans
    Donating Users blowfishRus6's Avatar
    g.a.
    if you already have the gear in first, then the tranny dont have to downshift. when your buddy nailed it he was probably in 3rd gear and the tranny had to switch down to second then down to first, thus taking longer to take off. if your roll racing an auto you have to hit it a little before the third honk or your gonna get left while the tranny is downshifting. if you go ahead and put it in gear, it doesent have to downshift. BUT at the same time, if your buddy had nailed it a little before the last honk and his tranny ALSO was in first and dident have to downshift, it would be a close race.
    go to the drag strip. run the car in manual, then run it in drive. you will get the same time. ive done it myself, and most of the time i ran slower in manual mode. even if you drop it in one or let the tranny do it itself, its still the same gear, no matter what.
    long story short. you won the race because he was waiting for his tranny to down shift.
    but theres ways around that, i have no problem roll racing, you just gotta know to hit the gas a little early so the tranny can start downshifting, no biggie.
    FTW means for the win
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  2. #42 Re: Downshifting an automatic trans
    g.a.
    go back and do a 10 roll with your buddy. you can put it in first if you want. at 10mph the car is still in first, well atleast mine is so there will be no need for downshifting. the race will be much closer.
    you would be suprised how much of a difference a slight reaction can make on a race.
    its slow.
  3. #43 Re: Downshifting an automatic trans
    Jersey
    projectgtp just get a shift kit.
    16' wrx sti- stock
  4. #44 Re: Downshifting an automatic trans
    g.a.
    and a pcm tune to allow skip shifts
    its slow.
  5. #45 Re: Downshifting an automatic trans
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    My tires just effin spin when im doing under 15mph. Kinds sucks >:|
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  6. #46 Re: Downshifting an automatic trans
    g.a.
    better tires... or roll into it. mine will spin some if i stand on it at 10 (tranny still in first) hell sometimes they just spin all the way threw first. sometimes they give a few little chirps and hook. guess alot has to do with the road surface and temp of the road.
    im running ****ty goodyears but 235s and lower air pressure. i like traction
    its slow.
  7. #47 Re: Downshifting an automatic trans
  8. #48 Re: Downshifting an automatic trans
    g.a.
    i can get up into second sometimes but not threw it :/
    its slow.
  9. #49 Re: Downshifting an automatic trans
    just kidding, i drive like a grandma. i havent ever seen the 11 pounds of boost my car makes.
  10. #50 Re: Downshifting an automatic trans
    Barksdale AFB, LA
    Quote Originally Posted by projectGTP View Post
    ok but i raced my friend with a 00 GTP with the same mods i have and i put mine in 1st gear and he left his in drive, when he honked three times i pulled about 8 lengths on him. im not making this up, it was really around 8. and he asked how i took off so fast. i told him and he tried it but from a 55 roll so we were in 2nd gear, and it was a much closer race than with him leaving it in drive. i have a 3.4 pully, 180 thermo, plugs, msd wires, AC delete, and resonator delete. he didnt have the AC delete which i heard is only a 2hp difference
    That's because the stock PCM sucks for shifting some times. There are areas it won't go all the way down to first from third, but instead go to second which severely limits acceleration. Nothing a quick PCM tune can't fix, so you don't have to abuse your transmission to get it to work right.
    2009 Subaru Impreza WRX STI
  11. #51 Re: Downshifting an automatic trans
    g.a.
    right... and im barak obama
    its slow.
  12. #52 Re: Downshifting an automatic trans
    Jersey
    Quote Originally Posted by blowfishRus6 View Post
    16' wrx sti- stock
  13. #53 Re: Downshifting an automatic trans
    i have a record of about 8 cars passed in one stint. passing zones rule.
  14. #54 Re: Downshifting an automatic trans
    g.a.
    ha damn
    its slow.
  15. #55 Re: Downshifting an automatic trans
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    and with downshifting it to first and nailing it. its just more of a jerk, makes it feel faster. but its not
    TORQUE FTMFW!!!
    Thats what makes it feel faster, increased pressure against the drivers body.
    Shift Kits w/ RMVB FTW!!
    Wonder if they make a shift kit for the GP....I havnt seen one yet but I dont even know what tranny is in the car, ive been lost the demise of the turbo hydramatic.
  16. #56 Re: Downshifting an automatic trans
  17. #57 Re: Downshifting an automatic trans
    g.a.
    if you leave it in drive its gonna be just as fast tho
    its slow.
  18. #58 Re: Downshifting an automatic trans
    I live here. UR LOSN's Avatar
    Rockford, IL
    try spinning through 3rd........
    it would be a fun ride if it happened to me sometime!
  19. #59 Re: Downshifting an automatic trans
    Dec 2008
    indiana
    Quote Originally Posted by 99prixgt View Post
    yeah, imma get that in the spring time when the weather gets warmer. any recommendation on tranny fluid i should run when i drain it? even tho i wont get all 100% of the old fluid out.
  20. #60 Re: Downshifting an automatic trans
    Dec 2008
    indiana
    yeah i know exactly what ur sayin. i just meant to say that it would be better to race in 1st when goin from a roll. but i guess the pcm and shift kit help out with that. thanks for not leaving sarcastic messages and instead teaching me more than i know now.
  1. converting from automatic to manual
    By 3800John in forum 1991-1994 5 speed Manual (GETRAG 284,282)
    Last Post: 03-29-2010, 07:36 PM
  2. Automatic Downshifting
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-23-2008, 08:12 PM
  3. Trans has a hard time downshifting when its cold?
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-28-2008, 10:38 AM
  4. Automatic CLimate control lights.
    By RichCresci in forum Visual/Body Modifications
    Last Post: 08-15-2008, 09:35 AM
