Yes had the same problem. Use a multimeter set to ohms. Pull the ABS connector at the wheel and use the meter to measure resistance of the hub sensor. With the sensor disconnected, insert the multimeter probes i to both connector contacts. Resistance should measure between 800- 1300 ohms. If no reading or infi ity, the hub bearing is bad.
Sent from my SPH-L720 using Tapatalk
