Thread: L36 n/a mods including top swap
Results 1 to 20 of 37
  1. #1 L36 n/a mods including top swap
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hi I'm new to the forum and had some question about my project. I just got a 99 Gp Gt coupe with 90k on it, I've had it for a couple months and it runs great but I want more power. I would be happy with being able to run with a gtp so my question is top swap or should I leave it n/a and what mods should I get. I am an OK do it yourselfr but have only gotten as deep as replacing lim and water pumps kinda low level experience like that. Can someone explain how had it would be to do a top swap and prices of getting to my goal.
    Sent from my LG-D851 using Tapatalk
  2. #2 Re: L36 n/a mods including top swap
    Aug 2013
    McDonald PA
    There's a write up on here for the top swa
  3. #3 Re: L36 n/a mods including top swap
    im running a top swap with a mild head port and 1.95 rockers and headers, stock pulley. it pulls damn nice.
    my car came sc and it blew up, so i technically bottom swapped it. so i have a hd tranny.
  4. #4 Re: L36 n/a mods including top swap
    Oct 2015
    Could you post a link for the top swap post, I searched for about an hour and couldn't find anything. :\
  5. #5 Re: L36 n/a mods including top swap
  6. #6 Re: L36 n/a mods including top swap
    Oct 2015
    Thank you very much its perfect!! Now if I decided to stay n/a could I achieve my 200whp basically what a stock gtp puts out with rockers and Bolt-ons I don't believe I'm experienced enough to do a cam by myself.
  7. #7 Re: L36 n/a mods including top swap
    Oct 2015
    I found a guy that has a 98 gtp motor that has a spun bearing but I asked him how much for everything from the heads and up and he said 120$ (he does not have the m90) is this a good deal? And what should I look for as far as potential damage or wear the parts might have. Could the spun bearing damage the heads? Thanks!
  8. #8 Re: L36 n/a mods including top swap
    id try to beat em down some, at a junk yard heads are like 30 or 40 a side.
    theres a gen 5 blower and lim for sale on the site here rather cheap too.
  9. #9 Re: L36 n/a mods including top swap
    N/A needs cam swap to even come close to 200whp on motor, along with plog/downpipe/rockers/hv3 and whatever else.
    Also note that whatever you decide to do, you'll want a custom tune with a wideband installed in the vehicle. And most "shops" don't do 3800 cars as most are either LS based or Euro/DSM.
  10. #10 Re: L36 n/a mods including top swap
    Oct 2015
    Can't I get an intense or zzp tune for a topswap and what's a wideband?
  11. #11 Re: L36 n/a mods including top swap
    Oct 2015
    Scottydoggs how much better is the gen 5 over the 3
  12. #12 Re: L36 n/a mods including top swap
    Nope.
    You are taking a high compression block and adding boost, it was never designed for boost. A "canned"/"Bought" tune will not be good enough.
    Google wideband and what it does, you have alot of reading to do.
  13. #13 Re: L36 n/a mods including top swap
    its a little better. gen 3's are cheaper still and do the job.
    a wideband is a air fuel sensor. works off a o2 sensor you install in the exhaust.
  14. #14 Re: L36 n/a mods including top swap
    Nope.
    you can get a canned tune, but in car is so much better. what i have, self tuned.
    you also need headers for a top swap.
  15. #15 Re: L36 n/a mods including top swap
    I'm not giving away free answers, you want to mod a car read up and do it the right way.
    A canned tune will never suffice. Every motor with a top swap is going to respond different, I wouldn't risk my motor over it.
  16. #16 Re: L36 n/a mods including top swap
    Oct 2015
    The l67 heads? Or aftermarket due to the high compression?
  17. #17 Re: L36 n/a mods including top swap
    l67 heads, or l32 heads.
  18. #18 Re: L36 n/a mods including top swap
    Oct 2015
    Fivefinger I read a how to on top swaps here on the forum it didn't say anything about installing a wideband or headers for that matter so I'm just trying to figure out if there's anything I'm missing that wasn't in the tutorial.
  19. #19 Re: L36 n/a mods including top swap
    Oct 2015
    Ya the guy is throwing in the l67 heads. How are the l36 and l67 headers different
  20. #20 Re: L36 n/a mods including top swap
    I updated the thread now.
  1. top swap finished, just scored a gen v now what for supporting mods?
    By randybill in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-01-2015, 10:19 AM
  2. 2000 Gtp with l32 swap and small mods
    By MrClean in forum For Sale - Vehicles
    Last Post: 04-13-2012, 11:13 PM
  3. Engine Swap/Mods?
    By Remnant King in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2011, 08:33 PM
  4. good avice on engine mods *not doing a top swap*
    By GrandPrixGT00 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-21-2009, 04:25 PM
  5. suporting mods for top swap
    By 05grndprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2009, 11:39 AM
