Thread: Bizarre situation with my '04 Grand Prix.
Results 1 to 20 of 21
  1. #1 Bizarre situation with my '04 Grand Prix.
    Oct 2015
    michigan city, IN
    It had been dying right after starting for awhile, not every time, but slowly getting worse(I would have to gun it to keep it from dying). Then yesterday, I had to start it like 5 times(most ever, not just dying this time, but not starting, did turn over ever time.). Finally got it started, but upon putting into Drive, the car began lurching forward, then slowing down, then lurching again, then slowing down, all by itself-throttle did NOTHING. I slowly turned around & "lurched" back to my driveway, then began making calls(no warning light came on, btw). About 15 minutes later I went out to start it so a tech could hear the engine "lurching", but then-this is the bizarre part-it totally "fixed" itself. Not only did it stop lurching, but it's starting better than maybe ever before, hasn't died once since, & the engine just generally sounds smoother & better than it has--perhaps since I've had it. & I keep going out & starting/running to make sure it continues, & it has. What in the world could this all be about? The only thing I can conceive is that maybe a hose or filter or something was obstructed & somehow blew itself clear? Idk. Curious is anyone has ever heard of something like this...Thanx!
  2. #2 Re: Bizarre situation with my '04 Grand Prix.
    it could be a lot of things, dirty, bad maf, to a bad tps, or the gas pedal. your have no throttle cable, its drive by wire.
    get the car scanned at a parts store it may have a pending code stored. the code is the key to the fix.
  3. #3 Re: Bizarre situation with my '04 Grand Prix.
    Oct 2015
    michigan city, IN
    Yeah, I've got a friend of a friend that's a mechanic who's going to bring home some equipment tonight & hook it up to a diagnostic tomorrow for me. I'm not sure anything will show up at this point though?
  4. #4 Re: Bizarre situation with my '04 Grand Prix.
    when they act up like that most of the time a pending code will show up, if not set the cel light.
  5. #5 Re: Bizarre situation with my '04 Grand Prix.
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Pull the throttle body off and clean it.
  6. #6 Re: Bizarre situation with my '04 Grand Prix.
    Oct 2015
    michigan city, IN
    That's what I'm thinking too.
  7. #7 Re: Bizarre situation with my '04 Grand Prix.
    Sep 2015
    ohio
    my car was doing this and i changed the Mass Air Flow sensor and it worked just fine again.
  8. #8 Re: Bizarre situation with my '04 Grand Prix.
    Oct 2015
    michigan city, IN
    how hard is that to do?
  9. #9 Re: Bizarre situation with my '04 Grand Prix.
    easy its the plastic tube in the air intake from the air filter box. un plug it un clamp it, swap it.
    or try cleaning it with maf cleaner only.
  10. #10 Re: Bizarre situation with my '04 Grand Prix.
    Oct 2015
    michigan city, IN
    & another thing, if a shop tells me it needs to be replaced & that it can't be cleaned because of "too many wires in the way", how would you respond to that?
  11. #11 Re: Bizarre situation with my '04 Grand Prix.
    walk out never go back lol they dont want your business clearly.
    most of us do all our own work here. shops suck for the most part, and why pay for what we all can do if we try. you dont even need a huge took box. i ripped my engine out with little more then a 30 piece socket set.
  12. #12 Re: Bizarre situation with my '04 Grand Prix.
    Feb 2013
    37.295091, -121.930053
    first i would "roll on the floor laughing" than maybe after 10 mins of that then tell them its just a simple plug then shake my head and walk away
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  13. #13 Re: Bizarre situation with my '04 Grand Prix.
    Oct 2015
    michigan city, IN
    Okay, thanx for the advice. Only problem is: that's where I bought the car--it's supposedly under 113 part warranty, yet I've had 3 things go wrong(ignition cylinder locked up with the key in it a month after I bought it, neither the warranty there or a recall from GM would cover it(I believe it was caused by the weight of my key ring). Then the spring mount for my HUD broke( still is)& they wouldn't cover that, & now this alleged throttle body that they won't cover. I'm so tempted to never go back there, they are full of it! I can't pick my car up 'til tomorrow, but could you do me a huge favor tomorrow when I get my hands on the car-probably late morning, & just answer some questions I have--if you're home & online? Sooo appreciated, thanx!
  14. #14 Re: Bizarre situation with my '04 Grand Prix.
    theres a how to here for all them things. search around, you'll be so happy how easy most of it really is to fix.
  15. #15 Re: Bizarre situation with my '04 Grand Prix.
    Oct 2015
    michigan city, IN
    Thank you ScottyDoggs.
  16. #16 Re: Bizarre situation with my '04 Grand Prix.
    Oct 2015
    michigan city, IN
    Oh yeah, & what's more? They told me it would be 5-600$, then he told me there would be a 100$ diagnostic fee--after doing so! I told him I already had it diagnosed(I took it there to get the fuel pump replaced, which a mechanic friend diagnosed yesterday, which of course they dispute that, saying "those long droning noises upon turning the key are normal)& that if he'd told me that in the 1st place I would've just left. IOf they don;t waive that fee tomorrow when I go to get it? I'm seriously considering just telling them to keep it, I'm done.
  17. #17 Re: Bizarre situation with my '04 Grand Prix.
    that whine you hear for 3 to 5 seconds with the key to run only, is 100% normal. thats the pump priming the fuel system, so the shops not 100% full of morons.
  18. #18 Re: Bizarre situation with my '04 Grand Prix.
    Oct 2015
    michigan city, IN
    ok, thanx
  19. #19 Re: Bizarre situation with my '04 Grand Prix.
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    My car did exact same thing it was my wire on the number 6 cylinder was corroded. Start cheap spark plugs and wires.
    Sent from my SM-S820L using Tapatalk
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  20. #20 Re: Bizarre situation with my '04 Grand Prix.
    Oct 2015
    michigan city, IN
    Hmm. Is it possible for a bad throttle body to not show up on the diagnostic--& no warning light?
  1. Bizarre issue with key fob (Tried ALL obvious fixes)
    By komrad36 in forum General Tech Discussion
    Last Post: 08-08-2013, 10:34 PM
  2. Car vs car situation
    By Jevik in forum General Grand Prix Discussion
    Last Post: 06-28-2013, 12:29 PM
  3. ABS Situation
    By Egleone6 in forum General Grand Prix Discussion
    Last Post: 03-26-2012, 02:35 AM
  4. KR Situation
    By mechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2011, 12:42 PM
  5. stumped on this situation....
    By fst in forum General Tech Discussion
    Last Post: 02-24-2010, 03:32 PM
