Thread: Need advise from the OGs
Results 1 to 20 of 40
  1. #1 Re: Need advise from the OGs
    Quote Originally Posted by Itchy2500 View Post
    I don't know if you can run a 97 PCM in a 99 even with the harness.
    There's about a 13 wire difference to the pcm. But... I called Scott out on it and suggested using the 99 harness instead. It's very easy to mod a harness. Ask me how I know.
    My 97 Bonneville had a 99 L36 harness that I modded for the firewall connector (would be relay center in a W body) to work. Ran a 99 pcm. At one point before I had a dhp I needed to have the correct vin, hence I made an adapter from 97 pcm to 99 wiring harness connector. It's a lot of wires to map, solder and hope you get right on the first try because you literally have one night to do it. FWIW I turned the key and it fired right up.
  2. #2 Re: Need advise from the OGs
    Aug 2015
    Reno, Nevada
    Well Bill it turns out it's a 98. I know I'll still have to mod the 99 harness and will pm you when that day comes but since it's only a year difference could I use the 98 pcm?
    99 GP GT Coupe
    279,942 Miles
    K&N and de-badged
  3. #3 Re: Need advise from the OGs
    Quote Originally Posted by freestyler659 View Post
    if its a 98 pcm from the gtp, and your car is a 99 you could flash a 99 bin to it and make it work with some tuning changes like the tranny if you keep the na tranny.
    what im saying is you have two good pcm's now 98 and 99 will swap bins with no issue.
    a 97 pcm is its own animal and can only be used for a 97.
    if you ever figure out what way you want to go, pm me, i can make all them changes in the pcm for ya. you just need to ship me one of the pcm's.
  4. #4 Re: Need advise from the OGs
    Aug 2015
    Reno, Nevada
    Quote Originally Posted by WileyCoyote View Post
    Thanks Scotty! Yes I will send you a pm. As of now the gtp runs and shifts good so I'm going to swap both in at the same time.
    I drove it home like this. That's a Pontiac for you
    99 GP GT Coupe
    279,942 Miles
    K&N and de-badged
  1. G8 advise
    By thewaitinggame in forum Off Topic Discussion
    Last Post: 03-03-2012, 05:56 AM
  2. Need Help! Please advise......
    By tmackster in forum General Tech Discussion
    Last Post: 02-01-2011, 04:29 PM
  3. Looking for some advise
    By o0DarkHaven0o in forum General Tech Discussion
    Last Post: 05-23-2010, 09:31 PM
  4. need advise
    By boothe in forum Off Topic Discussion
    Last Post: 05-09-2010, 05:13 PM
  5. **NEED ADVISE** please help
    Last Post: 05-05-2010, 10:40 PM
