Thread: Need Help! Please advise......
Results 1 to 3 of 3
  1. #1 Need Help! Please advise......
    GT Level Member tmackster's Avatar
    San Antonio, TX
    okay..about 6 mnths ago my heater hoses cracked causing me to lose water and making my car overheat......i have since replaced the heater hoses (coolant elbows), radiator hose, & thermostat. However the radiator still is losing water causing my car to overheat still..A mechanic had informed me that there was air in the water system and there was a valve under the engine to get the air pressure out..he had sd that it was causing the air to evaporate quickly and that was where the water was going. I had never heard of this but my car is still overheating and i am having to put water in the radiator every couple of days...HELP ME! BC I AM RUNNING OUT OF IDEAS. I do not see any leaks under the engine. Could this be the work of a faulty water pump?
    '06 GP GT // Debadged // 20" Niche Venice rims w/toyo proxes4 tires, ram air inferno hood, front air dam, SE rear valance, black l.e.d. tail lights, CAI, MSD Ignition wires, Pioneer 6x9, & 10,000K HID headlights!!!
  2. #2 Re: Need Help! Please advise......
    Portland Oregon
    Is there water in your oil? Take out your plugs, any of them look steam cleaned? Sounds to me like you've blown a head gasket or cracked a head
  3. #3 Re: Need Help! Please advise......
    Texas
    Agreed as stated above. More than likely cracked the head or blew a headgasket. Fo a compression test and report back.
    85 Corvette
    01 TA
    03 Z06
  1. Looking for some advise
    By o0DarkHaven0o in forum General Tech Discussion
    Last Post: 05-23-2010, 09:31 PM
  2. need advise
    By boothe in forum Off Topic Discussion
    Last Post: 05-09-2010, 05:13 PM
  3. **NEED ADVISE** please help
    By tmackster in forum General Tech Discussion
    Last Post: 05-05-2010, 10:40 PM
  4. Hello and some advise please.
    By Pontiacfan in forum Introductions/Noob Questions
    Last Post: 09-03-2009, 05:03 PM
