Thread: Downstream o2 sensor delete?
Results 1 to 6 of 6
  1. #1 Downstream o2 sensor delete?
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    I got this zzp 400 cell downpipe installed into my gp now. The car sounds a little louder than it did. I am not too worried about it being loud, I am thinking I didn't line up the gasket that goes from the downpipe to the resonator, I seen some liquid slowly leaking.
    My problem is this, i got a new o2 sensor that goes into the cat. My o2 sensor is starting to strip, I cannot get it to start threading, will it be possible to just put a plug and delete the downstream sensor, or should I try to re thread the o2 sensor, the threads on the downpipe are not too bad, but being under the car with jack stands is a pain.
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  2. #2 Re: Downstream o2 sensor delete?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Mirraco View Post
    It only goes one way, so there is no lining up to do.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: Downstream o2 sensor delete?
    Aug 2012
    Brainerd, MN
    Yeah I am not sure, I will try to tighten them some more. Is there any disadvatages to deleting the rear o2 sensor? I found a plug, then a emulator I think its called that plugs into the where the sensor plugs into.
  4. #4 Re: Downstream o2 sensor delete?
    you have a 01, its gonna over fuel on you because of that dumb cat test bs. aka you need your o2.
  5. #5 Re: Downstream o2 sensor delete?
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    you stripped a new O2 sensor in a new downpipe ?
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  6. #6 Re: Downstream o2 sensor delete?
    Nov 2013
    Wisconsin!
    ^this!!
  1. open end wrench that can take off downstream o2 sensor?
    By MrDniceL36 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-28-2014, 09:24 AM
  2. no downstream 02 sensor on my 04 Impala SS at the moment, is that ok ?
    By ryangtp89 in forum General Grand Prix Discussion
    Last Post: 07-11-2014, 07:24 PM
  3. o2 sensor ( downstream) STUCK!!!!!
    By mtnman in forum General Tech Discussion
    Last Post: 03-20-2013, 10:32 PM
  4. Can't get downstream 02 sensor off
    By chantspel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-22-2010, 12:25 PM
  5. downstream oxygen sensor replacement help!
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2010, 08:41 PM
