Thread: Hot running temp for my 2004 GTP
Results 1 to 7 of 7
  1. #1 Hot running temp for my 2004 GTP
    Jun 2015
    Millington, TN
    My temp gauge regularly sits on the last line (@239 degrees) before the "red" zone of my engine temp gauge when idling. The fan kicks into high gear after it gets there and really doesn't do much when it does. The only thing that brings the temp back down is airflow from driving it around. Had the cooling system flushed by auto shop in the past year. Replaced the thermostat in the past 2 years. Both fans work. Running out of options that I am aware of. Thanks for the help!
    Curt M.
  2. #2 Re: Hot running temp for my 2004 GTP
    Nov 2011
    NY
    System is blocked or you have small leak letting air in system, need new thermostat?
  3. #3 Re: Hot running temp for my 2004 GTP
    May 2015
    FORT WAYNE, INDIANA
    This is just a guess but wonder if temp sensor could be bad w/o triggering a trouble code? Has check engine ever come on?
  4. #4 Re: Hot running temp for my 2004 GTP
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    I would second the radiator is probably blocked up. When i did my cam in march i flushed mine multiple times and you wouldn't believe some of the gunk that came out of it. That gm dexcool bs is a radiator killer. Flush it yourself, make sure it's full and burped then if it's still reading stupid start checking sensors.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  5. #5 Re: Hot running temp for my 2004 GTP
    Jun 2015
    Millington, TN
    So I feel like a complete tool. I figured the place that did the coolant flush would have ensured I had plenty of coolant. I was wrong. Burped the system, filled the reservoir with 50/50 and everything leveled out. So thankful it never overheated. Thank you all for the attention in this matter. I hope I can be of service to you in the future.
  6. #6 Re: Hot running temp for my 2004 GTP
    Aug 2013
    arlington, tx
    They probably didn't top it off after they turned the car on
  7. #7 Re: Hot running temp for my 2004 GTP
    Jan 2013
    Raleigh, NC
    Quote Originally Posted by cmetzger View Post
    Happens dude. Glad you got it fixed. Summer is bad time to have cooling issues.
  1. High Temp Light Coming On When Running AC
    By scross in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-08-2012, 08:48 PM
  2. what temp should i be running at
    By nicks98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2011, 06:21 AM
  3. 97 Grand Prix Running at High Temp
    By jpearsall187 in forum Engine
    Last Post: 04-16-2011, 08:30 PM
  4. Temp Gauge running hot
    By Thexfactord22 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2010, 02:43 AM
  5. Car won't stay running - Coolant Temp and TPS sensor problem?
    By David A Smith in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2010, 10:37 PM
