Thread: Temp Gauge running hot
Results 1 to 7 of 7
  1. #1 Temp Gauge running hot
    Southfield, Mi
    I have a 03 Grand Prix Gt, my temperature gauge is always running hot when the car is not actually heating up. I hooked the car up to a computer/scanner and the scanner reads 210-219 but the gauge is all the way up at 235. I just replaced the temp sensor and i dont seem to understand why this is happening.
  2. #2 Re: Temp Gauge running hot
    Southfield, Mi
    Also could the sensor be the problem, if so how is the scanner getting the right reading if the sensor is bad?
  3. #3 Re: Temp Gauge running hot
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    hey fellow southfielder. i have seen others do this also...maybe sensor again. could be the guage i guess. i dunno the year ....
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  4. #4 Re: Temp Gauge running hot
    Southfield, Mi
    The year is 2003 i just got a new sensor, and im putting in in as soon as the car cools down. Ill let u guys know what happens.
  5. #5 Re: Temp Gauge running hot
    Charles City, IA
    Probably the gauge its self.
    SMGPFC Two Nipple General
  6. #6 Re: Temp Gauge running hot
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    I have gotten sensors that are off. there is 2 sides to the sensor. One side is for your pcm and the other side works your gauge.
    My EX wifes other car is a broom.
  7. #7 Re: Temp Gauge running hot
    Southfield, Mi
    Alright, i replaced the sensor and the gauge works perfectly now. I just hope it stays that way.
  1. 94 GP with fluctuating temp gauge
    By Beyond Hope in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-22-2010, 09:19 AM
  2. Car won't stay running - Coolant Temp and TPS sensor problem?
    By David A Smith in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2010, 10:37 PM
  3. Does anybody know how to calibrate the temp gauge without a scanner?
    By corsagtp in forum Visual/Body Modifications
    Last Post: 02-26-2010, 02:37 AM
  4. Temp gauge
    By SnowDrift in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2009, 01:39 AM
