Thread: Stumbling then stall cold and warm start.
Page 1 of 3 123 LastLast
Results 1 to 20 of 51
  1. #1 Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    So ever since I got my exhaust work done my car has been acting odd. First I'm thinking its the for but I'm not sure. On cold and warm starts it stumbles and stalls if I don't press on the gas to at least 1k rpm sometimes 2k rpm. Some times I get the p0420 code. My o2 sensor seems to move slowly and doesn't even reach 9mv according to my torque app. My iac is around 58 My maf use to be around 5.4 now its over 6 and goes up when it starts to stumble. Also when it does stumble I can hear the vacuum pulling close to 0 before it stalls. Please help.
  2. #2 Re: Stumbling then stall cold and warm start.
    Year, make, model??
    Ever tried cleaning the throttle body itself and the MAF sensor?
    Maybe you have a vacuum leak aswell.
  3. #3 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    No I was going to do that when I do my lim gaskets, but my boost gauge stays at -20 so it can't be a vac leak
  4. #4 Re: Stumbling then stall cold and warm start.
    Map in/hgs do not matter, you can still have a vacuum leak. The IAC and MAF sensor are smart enough to correct for minor issues.
    You'd want to watch fuel trims, watch what the o2 sensors are relaying back to the computers. If the number is at 16.4+ or so, then a vacuum leak is present.
  5. #5 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    My ltft is around 8 and the short term is around -4
  6. #6 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    Well I changed out the fuel pressure regulator which didn't help. Now I'm on to cleaning the maf, iac, and tb. Is there a way to clean this carbon build up inside the intake safely?
  7. #7 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    Well the cleaning didn't help, nor disconnecting the battery. So now I'm thinking the o2 sensor? On another note, I broke a stud in the TB.. Great. Now it's leaking coolant.......I just can't catch a break.
  8. #8 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    Update: since the cleaning it's been acting normal somewhat, but when Idling it feels like the engine is slightly misfiring. You can't notice it unless you're actually paying attention.
  9. #9 Re: Stumbling then stall cold and warm start.
    GXP Level Member
    Mar 2015
    Tomball
    check your vacuum lines, mine was giving me fits and I ended up tywraping all of the hose connections and the stumbling went away.
  10. #10 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    I already went over those and replaced most of the line fittings with silicone hose
  11. #11 Re: Stumbling then stall cold and warm start.
    Sep 2014
    Worcester, MA
    Subscribed - this happens to me on both cars too, and I've cleaned out the intake tract.
  12. #12 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    Did you change any ignition components? This is what I'm doing next
  13. #13 Re: Stumbling then stall cold and warm start.
    Sep 2014
    Worcester, MA
    On a former car, I changed out all of the ignition except coils. On the two cars I have now, I have only changed out plugs & wires.
    In my mind, even a poor ignition is still sufficient to get the job done under startup conditions - since my engines run great under much heavier loads, it seems that the ignition should have a "breeze" of a time getting the job done at idle.
  14. #14 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    So it must be my o2. I got code p0133 and p0440
  15. #15 Re: Stumbling then stall cold and warm start.
    GXP Level Member
    Mar 2015
    Tomball
    Or you could still have a vacuum leak...
  16. #16 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    True but where? The lim? This started happening after I had my stock downpipe but in, a resonator, and mufflers.
  17. #17 Re: Stumbling then stall cold and warm start.
    GXP Level Member
    Mar 2015
    Tomball
    I guessing you checked the EVAP lines? Have you tried the propane torch test? The O2 slow response and EVAP codes can and have been known to be caused by vacuum leaks. I have chased vacuum leaks for a week and still seem to find another one just about every day. Brake booster vacuum line, the other end of the line. The connection to the MAP (both ends, at the MAP and the tube to elbow). Fitting at the front of the SC under the snout, the other 2 connections on that T. The bypass solenoid and the line to the bypass solenoid itself. The other end of the bypass valve (each end). You have to remember a lot of these lines are not only under vacuum but pressure as well and with it flip flopping between vacuum and boost so it's pushing and pulling on the lines all the time (the ones on the outlet side of the blower anyway).
    Jeff
  18. #18 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    What's the propane torch test? I'm going to order some silicone hose and replace everything
  19. #19 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    Are any of the lines by the charcoal canister by the drivers side rear wheel a place to check for leaks?
  20. #20 Re: Stumbling then stall cold and warm start.
    GXP Level Member
    Mar 2015
    Tomball
    The propane test is using a propane torch with a length of tubing fit over the end. Start the car, preferably cold, slightly turn on the torch. Not enough to light it but just enough so you can use the tube end to probe areas that you think may have a leak. When you get to the vacuum leak the idle will change. If you don't feel confident doing it don't. Mechanics have used this sinc way before I was born.
    Can't help you with the routing, I've had several BOP cars with the 3.8, but most weren't SC'd and my GP is an 05'. I'm sure someone else will chime in though.
    Jeff
  1. Warm Start Stall - Stumped
    By Yonkerse in forum General Tech Discussion
    Last Post: 12-09-2014, 11:20 AM
  2. 02 GT heater blows warm air, then cold, then warm, etc.
    By skeelo58 in forum General Tech Discussion
    Last Post: 03-04-2014, 08:52 PM
  3. Bucking on acceleration and stumbling idle at cold start
    By 1999GrandPrix in forum General Tech Discussion
    Last Post: 02-08-2012, 02:21 PM
  4. why is my idle so low on cold start and sometimes fully warm?
    By 04silvercompg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2012, 02:49 PM
  5. warm start weak idle 50/50 will stall immediately
    By Crims in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-07-2011, 02:47 AM
