Thread: warm start weak idle 50/50 will stall immediately
Results 1 to 4 of 4
  1. #1 warm start weak idle 50/50 will stall immediately
    Iowa
    2005 Grand Prix: On a cold start my engine will start strong and loud. Warm start: it starts off with a weak idle and often dies immediately if i don't give it a pinch of gas ( i use 'pinch' because it doesn't take much, just a tap).
    Use 89 ethanol blend. Seem to get a stronger start when i use some kind of octane booster/injector cleaner. but every mechanic I've talked to says I shouldn't need to do that.
    One theory that has been brought up is because of the exhaust system changes i made. Took off the resonator and turned it into a cat back dual exhaust made the sensor (???? forgot which one) go haywire because of the exhaust pressure difference(?) (not mechanically inclined, so i don't remember the full details of the conversation).
    Was hoping someone here might have any ideas on why it happens or if the theory above is right.
  2. #2 Re: warm start weak idle 50/50 will stall immediately
    Do you have a check engine light lit up? If so..scan now before....or we will beat you down to scan it.
  3. #3 Re: warm start weak idle 50/50 will stall immediately
    Iowa
    no codes, been checked before and found nothing.
  4. #4 Re: warm start weak idle 50/50 will stall immediately
    Oct 2011
    Texas
    I have an 04 and I used to have the exact same problem. Take off the throttle body (4 bolts) and clean out all the carbon on the backside and front side with some carb cleaner and a brush or rag. Throw it back on there and you should be good.
  1. Won't start immediately after shut down
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2011, 09:02 AM
  2. High idle glowing hot manifolds weak power
    By Sig in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2011, 08:56 AM
  3. erratic idle, stall, one no start... NO CODES!! HELP
    By pur3vil in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-08-2010, 10:06 AM
  4. 4.0 Ford Explorer Weak Idle
    By SlowNA06 in forum Off Topic Discussion
    Last Post: 10-13-2010, 02:04 PM
  5. Surging idle when warm
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2010, 10:21 AM
