Thread: poor fuel mileage with zzp 1.0 pcm
Results 1 to 20 of 23
  1. #1 poor fuel mileage with zzp 1.0 pcm
    GT Level Member 99GPGTP's Avatar
    Rome GA
    heres the story. the transmission went out in my car 2 years ago. i just recently for it fixed.while the car sat the fuel pump went bad, i installed a AEM 320lph pump. i put new oil pan and timing cover gaskets on my motor while engine was out. Installed a ported m90 housing. and a zzp 1.0 pcm. car was only getting 13-14mpg around town. and 15-17 on hwy. which is almost half of what it used to get. i changed the injectors, o2s, tried a new mass air from a friends car. installed an adjustable fpr. even went back to my stock m90 housing. none of these changes made a difference. 3 days ago i put my stock pcm back in my car and the fuel mileage went back to 28-32mpg on hwy and 20-23mpg around town.
    has anyone else run in to this issue before or can tell me what i need to do to get my mileage back up with the zzp 1.0 pcm
    99gtp 3.4"on ported m90, zzp 1.0 pcm, speeddaddy headers, stock mufflers w/cat and res delete,104's,FWI,180* stat, exhaust ported heads,Dog bones flipped, 18" 350z wheels
  2. #2 Re: poor fuel mileage with zzp 1.0 pcm
    Bastard Reptile's Avatar
    Kansas City, MO
    They've probably done something in the programming. I doubt you're gonna get good mileage out of the ZZP one.
  3. #3 Re: poor fuel mileage with zzp 1.0 pcm
    Kemmerer, Wyoming
    I ran a zzp pcm on my first grand prix and still got reasonable gas mileage. not sure why yours would be different.
  4. #4 Re: poor fuel mileage with zzp 1.0 pcm
    Kansas City, MO
    They're hit and miss with them. I've seen some really goofy stuff in the programming before.
  5. #5 Re: poor fuel mileage with zzp 1.0 pcm
    Rome GA
    so i need to just get the hp tuners and tune it my self?
  6. #6 Re: poor fuel mileage with zzp 1.0 pcm
    Kansas City, MO
    That or you can get another PCM
  7. #7 Re: poor fuel mileage with zzp 1.0 pcm
    Kansas City, MO
    You didn't have any gearing changes in the transmission while you had it rebuilt, did you?
  8. #8 Re: poor fuel mileage with zzp 1.0 pcm
    Donating Users Uno99's Avatar
    Appleton, Wi
    My old ZZP 1.0 tune was extremely fat as well. Especially on cold startup and idle. Turned my good lookin tips all black is was so bad.
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  9. #9 Re: poor fuel mileage with zzp 1.0 pcm
    Rome GA
    Trans has same gearing. Did add a 2500 stall. But when in lockup it shouldn't matter. I wonder if i would hurt fuel mileage by putting the ported m90 back on.
  10. #10 Re: poor fuel mileage with zzp 1.0 pcm
    Nov 2011
    NY
    Maybe they avoid leaning out by dumping fuel and killing the efficiency? You've modded, are you monitoring? What's your afr?
  11. #11 Re: poor fuel mileage with zzp 1.0 pcm
    Rome GA
    miles calculation been with a calculator and tip adometer and gallons in
  12. #12 Re: poor fuel mileage with zzp 1.0 pcm
    Rome GA
    Quote Originally Posted by coolone View Post
    No afr gauge yet. That's the next mod i will do. But i have 0 kr with either pcm
  13. #13 Re: poor fuel mileage with zzp 1.0 pcm
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    I had a ZZP "Custom" can tune for my car. My LTFT's were ALL over the place, I mean +/- 17, it was insane, and my AEM Wideband would peg out at 10.0 at WOT.
    I have heard their tunes run rich, and my Wideband would clarify that - but only at WOT. Not sure if this matters, but my cruise timing on the highway with the ZZP Tune was roughly at 20* - not sure what stock is, though.
  14. #14 Re: poor fuel mileage with zzp 1.0 pcm
    Rome GA
    I will recheck my ltft. Last i saw they were up to +25 at idle
  15. #15 Re: poor fuel mileage with zzp 1.0 pcm
    Jun 2011
    Quote Originally Posted by 99GPGTP View Post
    Same here with ZZPoo tune.
    If you get 0* KR with your stock PCM, why bother using the ZZP one? Try to get an in-car tune, get a tune from Reptile (on this forum), or get a tune from Overkill Motorsports.
  16. #16 Re: poor fuel mileage with zzp 1.0 pcm
    Appleton, Wi
    Yep go with Retile or overkill i think overkill gives a $50 discount if you have some other companies tune and you go will one of theirs.
  17. #17 Re: poor fuel mileage with zzp 1.0 pcm
    Kansas City, MO
    If you send me the zzp one I'll cut you a deal, since I won't have to source one.
  18. #18 Re: poor fuel mileage with zzp 1.0 pcm
    Appleton, Wi
    Do it ^^^^^^^^^^^^^^
  19. #19 Re: poor fuel mileage with zzp 1.0 pcm
    Rome GA
    I'm driving 70mph cruise set. And my ltft is -11 and stft is 1 front o2 is reading 500-900mv. Baro reading 14.1psi
    map @ 4.4-6psi
  20. #20 Re: poor fuel mileage with zzp 1.0 pcm
    Rome GA
    Changed mass air and front o2 sensor. No change in fuel mileage. Still averaging 18mpg. Is the aem 320lph pump just way to much for my setup?
  1. 2005 GTP Poor Mileage... Please Help
    By whitefeathersnpr in forum General Tech Discussion
    Last Post: 06-09-2011, 08:17 AM
  2. Poor Gas Mileage??
    By Hawkins97 in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-06-2011, 04:53 PM
  3. Really Poor Gas Mileage
    By blortz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-20-2011, 12:28 AM
  4. Poor gas mileage
    By jackdup in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2010, 11:47 AM
  5. poor gas mileage
    By 05grandprixgt in forum General Tech Discussion
    Last Post: 02-14-2010, 07:32 AM
