Thread: Stumbling then stall cold and warm start.
Page 3 of 3 FirstFirst 123
Results 41 to 51 of 51
  1. #41 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    Lol
  2. #42 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    Question, when I unplug the maf sensor and TRY to drive it, it stalls and runs even worst, but mainly stalls. Since the map and maf works hand in hand does this mean I have a map problem?
  3. #43 Re: Stumbling then stall cold and warm start.
    are you unplugging the maf engine off, then starting it? if you unplug it running it will really run bad.
  4. #44 Re: Stumbling then stall cold and warm start.
    Kemmerer, Wyoming
    you can damage your maf if you unplug it with the engine running
  5. #45 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    No the engine was off
  6. #46 Re: Stumbling then stall cold and warm start.
    they dont run great with the maf un plugged. but if it runs better unplugged the maf is bad for sure. most of the time you get a code for the maf if its the issue.
  7. #47 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    Yeah, I figured if it didn't want to at least run without it then it had to be one of the other sensors
  8. #48 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    Thought it may have been my old pcm but Since I keep getting codes p0133 and p0134 with my new afs109 I'm going to purchase another so what's the difference between the afs109 and 2131331
  9. #49 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    So does this looks like the right schematic for the 2 o2 sensors on a l67?
    I already bought another o2 sensor if it doesn't work I'm going to have to do some hard wiring
  10. #50 Re: Stumbling then stall cold and warm start.
    Sep 2014
    chicago
    Well to help anyone with the same symptoms, yes it was my front o2 sensor. I read the instructions that came with my new o2 and it states do not drop. So ass I gathered my thoughts, my previous o2 sensor which was new had been sitting in my trunk along with my 2 15 inch sub's. So that o2 took a beaten for many months.
  11. #51 Re: Stumbling then stall cold and warm start.
    theres a lesson learned. good hear its running better.
  1. Warm Start Stall - Stumped
    By Yonkerse in forum General Tech Discussion
    Last Post: 12-09-2014, 11:20 AM
  2. 02 GT heater blows warm air, then cold, then warm, etc.
    By skeelo58 in forum General Tech Discussion
    Last Post: 03-04-2014, 08:52 PM
  3. Bucking on acceleration and stumbling idle at cold start
    By 1999GrandPrix in forum General Tech Discussion
    Last Post: 02-08-2012, 02:21 PM
  4. why is my idle so low on cold start and sometimes fully warm?
    By 04silvercompg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2012, 02:49 PM
  5. warm start weak idle 50/50 will stall immediately
    By Crims in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-07-2011, 02:47 AM
