Thread: Why might my cabin lights be staying on all of a sudden?
Results 1 to 14 of 14
  1. #1 Why might my cabin lights be staying on all of a sudden?
    SE Level Member Centauri's Avatar
    Sep 2014
    St. Paul, MN
    It started this morning and I noticed it on the drive to work. For the life of me, I can't think of what I might have done. They continue to stay on after I've left the car and set the alarm, but they do go off eventually (though I'm not sure how long exactly)
    Any idears?
  2. #2 Re: Why might my cabin lights be staying on all of a sudden?
    Jan 2014
    AR
    Might want to go see if the wheel below your headlight switch is cranked all the way to the fat end. That thing (on 97-03 GP) controls guage lighting brightness but if cranked all the way to bright, theres a detent and it switches your "dome light" on. Easy to bump the switch without knowing. Thats the manual dome light switch, its kind of a carry-over from the old days when you crank the headlight knob all the way left for inside lights. A tiptoe through the owner's manual can familiarize a driver with subtle features such as this one.
  3. #3 Re: Why might my cabin lights be staying on all of a sudden?
    Sep 2014
    St. Paul, MN
    Nope, already tried checking that.
  4. #4 Re: Why might my cabin lights be staying on all of a sudden?
    Jan 2014
    AR
    Glad to know basics are still on the front line! You open and shut all the doors yet? I believe the door switch is in the latches on these cars. It could get complicated, I defer to higher powers and have nothing further at his point. Electrical is my kryptonite, just thought I'd ask about that switch because I found mine on the other day. It does eventually time out, does it? Hmmm... good luck with it.
  5. #5 Re: Why might my cabin lights be staying on all of a sudden?
    Mar 2014
    Tucson
    Typically its a bad door actuator, but not always. I had the same symptoms but it was due to a different issue.
  6. #6 Re: Why might my cabin lights be staying on all of a sudden?
    Sep 2014
    St. Paul, MN
    Lock actuator or blend actuator?
    I've had gurgling sounds from within the dash due to, I assume, a supposedly bad driver's side blend actuator but was noticing today that the gurgling seems to have doubled.
    1999 Grand Prix GTP sedan
    Speed Daddy headers, 3.25" on a ZZP MPS, high-flow cat, 180
    ° t-stat, Autolite copper 104s, shift kit, ReptileTune...
  7. #7 Re: Why might my cabin lights be staying on all of a sudden?
    Mar 2014
    Tucson
    Quote Originally Posted by Centauri View Post
    Lock actuator. Part of the latch assembly. If you have a DVOM, you can check functionality of each actuator at the BCM. No need to pull the door panels unless or until you find a bad actuator.
    Like I say, door actuator is MOST likely, but other possible causes are faulty headlamp switch, faulty BCM, or short to ground on courtesy lamp circuit.
    I can't imagine a faulty blend door actuator causing a "gurgling" sound. Usually bubbling or gurgling in the dash is from air in the heater core. Haven't had to fight that problem yet. I'll let someone else chime in on that issue.
    I'll focus on the lighting problem because I've been there before.
    Let me know if it turns out NOT to be an actuator. I can send you some trouble trees to work through to narrow down the cause.
  8. #8 Re: Why might my cabin lights be staying on all of a sudden?
    Sep 2014
    St. Paul, MN
    I'll have to have a friend test the actuator but in the meantime I pulled the interior lights fuse and all of the lights do go off. I even switched it with another 01 fuse but my problem remains.
    I was noticing too that I can sometimes get the dome lights to go off by playing with the wheel underneath the headlamp control knob. But everything else stays on. Hmm...
    You know, this all started yesterday when I left my driver's door open after I started the car up and let it run as I walked to the mail box, which is something I've never done before.
  9. #9 Re: Why might my cabin lights be staying on all of a sudden?
    hangover park IL
    I pulled the fuse on my 97 because my drivers door lock actuator switch was bad....it's cheaper to just use a small LED flashlight in the cubby hole
    ~James~ Psychotic Gearhead
  10. #10 Re: Why might my cabin lights be staying on all of a sudden?
    Jan 2014
    AR
    Play with it faster! Just kidding, that didn't sound right did it? The parts inside that headlight switch could just be dirty from lack of use. Do like we did back when twisting the old-school knob made the dash lights flicker... work the switch back and forth vigorously and repeatedly. That might fix it. Or at least tell you theres an issue in the headlight switch.
  11. #11 Re: Why might my cabin lights be staying on all of a sudden?
    that dimmer wheel for the dash lights, clicks at the brightest setting and the inside lights come on. iirc thats part of the head light switch, it goes bad.
  12. #12 Re: Why might my cabin lights be staying on all of a sudden?
    Mar 2014
    Tucson
    Quote Originally Posted by idrivejunk View Post
    I suppose that's possible also. It's crazy dusty here.
  13. #13 Re: Why might my cabin lights be staying on all of a sudden?
    Jan 2014
    AR
    It happens to all the stuff with rheostats or whatever those spring lookin thingys are called, that dim the dash lights. Thats why I brought it up first thing, so you would notice any funny business if you cycled the switch. Anybody remember scratchy-sounding volume knobs on stereos? Same thang, just work hell outta the switch to buy time until you can replace the whole switch or clean it.
    Edit: this still might not be the whole issue!
  14. #14 Re: Why might my cabin lights be staying on all of a sudden?
    GT Level Member sugaryuk's Avatar
    vancouver,bc
    I had a similar problem with my 97 years ago...turned out that battery acid had dripped onto the wiring harness that runs underneath the battery and corroded some of the wires, causing all sort of weird electrical glitches. Cleaned it up and patched the broken wires and then all was good. Might be worth taking a quick look.
    02 GT- L32/Gen V, 3.3 mps, zz 1.9's, N*, slp front to back, OverKilled, 180 tstat, 104's, K&N cai, lowered with GMMP susp, 12" PBR brakes
    75 Pro-Street Vega-- Blown 383 stroker with Nos fogger system
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. ABS Light staying on
    By 98IndyGP in forum General Tech Discussion
    Last Post: 07-19-2012, 10:25 AM
  3. HELP!!! DRL's Staying On
    By kodeblue in forum General Tech Discussion
    Last Post: 01-21-2012, 02:53 AM
  4. wipers staying up
    By Jakegday in forum General Tech Discussion
    Last Post: 12-15-2009, 03:35 PM
  5. abs and trac off light staying on
    By gtpinsc in forum General Tech Discussion
    Last Post: 08-20-2008, 07:34 AM
