Thread: High output alternator pulley siZe
Results 1 to 4 of 4
  1. #1 High output alternator pulley siZe
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    I bought a high output alternator the pulley on it is way smaller. Now can I just take my pulley off the oem one? How much would that drop the output that it's giving out. Or I can get a way smaller belt I tried one that's 3/8th inch smaller and it still was too big it has to be over a inch smaller pulley
  2. #2 Re: High output alternator pulley siZe
    Buffalo
    If it's the $200 eBay "high output" I would return it.
    He uses the smaller pulley to mimic a high output at idle and cruise. Also the comments of other buyers show it's within stock ratings when they had it tested.
    If it's not the eBay one , the smaller pulley may only help at idle as well but the maker of the alternator can give you the specific output at specific rpm ranges.
  3. #3 Re: High output alternator pulley siZe
    Aug 2012
    Brainerd, MN
    Quote Originally Posted by crazyguy03 View Post
    I bought it from the db website. Got it all hooked up with the oem pulley. Is it same rating with the oem pulley or did i lose alot of the amps? Its 220 amp one
  4. #4 Re: High output alternator pulley siZe
    Buffalo
    It's output vs rpm You might not get full output at idle with a larger pulley. Got to ask the maker for a spec sheet
  1. high output alternator 98 gtp
    By Ricky Garcia in forum Audio, Security & Visual Electronics
    Last Post: 07-01-2014, 11:59 PM
  2. High Output Alternator
    By KitRae in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-09-2014, 09:16 AM
  3. high output alternator for 97 gtp
    By blakgtp in forum Audio, Security & Visual Electronics
    Last Post: 04-21-2013, 02:04 AM
  4. High output alternator vs battery
    By deathjunior in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2011, 11:14 PM
