Fivefingerdeathpunch
Yes, take it off. It's only like 4 bolts, the rubber gasket can be used again, just clean it up some.
Unplug the throttle body, remove it and spray it down with carb cleaner or brake cleaner. Either will work and you can use a brush if you want aswell.
Just DO NOT open the throttle blade with your hands, clean in and around but it's not a good idea to push it open as it a electronic unit and sometimes they need a relearn when it's been opened.
