Thread: 00 GTP struggles to run after starting,dies after a few seconds.
Results 1 to 3 of 3
  1. #1 00 GTP struggles to run after starting,dies after a few seconds.
    Jun 2012
    Iowa
    Hey guys my 2000 gtp has developed an odd problem. When I start the car it starts right up fine but will almost immediately struggle to stay running. It will die after about 2 or 3 sec after start up chugging and trying to run the entire time. I can keep it running if I put my foot on the pedal and keep it around normal idle. Obviously the car runs better with me helping it but it still doesnt sound perfect.
    This problem started about 1 month ago. Car ran fine and I got some gas and it wouldnt stay running. I ended up bending the 85 pin back on the relay and unplugging the maf and the car ran good and got me home without dying or struggling at all. I cleaned the maf up and the car went back to normal up until about a week ago.
    I put a new IAC in back before this happened cause my idle was a little odd if that helps. Ive tried 2 dif mafs (both spotless) and just put in a new fuel filter yesterday. Checked for vac leaks and nothing came up. Fuel pump primes and I can audibly hear it when I turn the key. My last guess would be the FPR but when I pulled the line off no gas came out and apparently if gas comes out then its bad. As far as CELs go I cant tell you for sure if I have one realted to the problem. I usually have on one for the rear 02 and the light comes and goes cause Im usually disconnecting the battery because sometimes my key wont come out with the car dying and locking the key in.
    Any help/suggestions would be awesome. Thanks!
  2. #2 Re: 00 GTP struggles to run after starting,dies after a few seconds.
    Feb 2014
    Milwaukee
    Fuel pump resistor. My regal did the same thing.
  3. #3 Re: 00 GTP struggles to run after starting,dies after a few seconds.
    Donating Users Uno99's Avatar
    Appleton, Wi
    I chased pretty much the same issue......thinking fuel pump but ended up being the Air Intake Charge Temp Sensor/Valve http://www.rockauto.com/catalog/x,ca...,parttype,6072
    Swapped it out and ive been ok for a few weeks now.
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  1. P0453 runs for a couple seconds then dies
    By aeidian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2014, 04:06 PM
  2. Need Help with '98 gtp starting then shutting off after seconds.
    By ryanroos in forum General Grand Prix Discussion
    Last Post: 01-24-2013, 07:13 PM
  3. Cars starts then within seconds DIES!
    By MistyChameleon in forum General Tech Discussion
    Last Post: 07-15-2011, 03:34 PM
  4. Idles for 5 seconds then dies
    By 00grandprix in forum Engine
    Last Post: 04-30-2011, 04:32 PM
  5. GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    By 93Chewbacca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2011, 09:38 PM
