Thread: bout to give up
Results 1 to 20 of 34
  1. #1 bout to give up
    Jul 2013
    Sheffield,Pa
    My sons car..
    The engine cuts out every so often. At idle, it revs some on its own..
    what I've done,
    1. new plugs and wires ( which needed changed anyway 131K)
    2. all new coils
    3. new gas cap
    4. the supercharger was rattleing, so we just changed the coupler..sound is gone now...coupler was deffinately worn
    but now back to why is the engine cutting out..Any ideas????
  2. #2 Re: bout to give up
    Donating Users timboku's Avatar
    Montgomery, IL
    Maf sensor.
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  3. #3 Re: bout to give up
    St. Louis
    Does it die while he is driving? Ever notice the tach dropping to 0 before it shuts off? Could be a crank position sensor. But I would start by removing and cleaning the MAF with approved cleaner and try that. Is the CEL on? What type of plugs did you put in?
  4. #4 Re: bout to give up
    GT Level Member chamberlain198437's Avatar
    Grants Pass Oregon
    I would look at the idle air control valve, and check the fuel pressure. Just and idle problem, or does the car surge while driving? Could start with iac the inexpensive, easy to replace. Incorrect fuel pressure would cause this to causing the iac to have incorrect readings. If the car surged while driving i would suspect a tps, but it sounds like you just have an idle problem. The crank position sensor will cause random stalls to, combine with vacuum leaks would cause a high idle. But i would start with the iac and fuel pressure. Hope this helps a little, there's always a few other things it could be.
  5. #5 Re: bout to give up
    what year is the car? and did you check for vac leaks yet. one may have broke when you did the coupler. or they break with no help too.
  6. #6 Re: bout to give up
    Jul 2013
    Sheffield,Pa
    it also surges/cuts out while driving. RPMS don't drop to zero, but a couple hundred RPMs or so
    just cleaned the MAF, with the CRC MAF cleaner
  7. #7 Re: bout to give up
    Jul 2013
    Sheffield,Pa
    its a 99 GTP
  8. #8 Re: bout to give up
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Are the plugs gapped correctly?
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  9. #9 Re: bout to give up
    Jul 2013
    Sheffield,Pa
    Yes, did it before the plugs were installed, and after
  10. #10 Re: bout to give up
    Florida
    First, does it have any SES codes?
    Unplug the MAF entirely with the car off. Start it up and let it idle for a minute then drive it. See if it does the same thing. If it is fine, then it is the MAF. (I've had this happen before even after cleaning the MAF)
    Check and see how much vacuum you are pulling at idle. Should be 18-20 in/hg
    Check your battery connections and all your grounds and ensure they are tight and have good connection.
    Lastly, when was the fuel filter replaced last? Usually they only present issues at higher rpm with fuel starvation, but I've seen them cause issues throughout the range before.
  11. #11 Re: bout to give up
    GT Level Member Yarbeau's Avatar
    Jun 2010
    Edmonton
    I had similar issues to you and followed every tip on the forums. New maf, fuel filter, fuel pump, Changed the crank position sensor and even Went back to stock wires with new plugs! Nothing helped.
    It turned out to be the plate underneath the coils (ignition control module). Had a spare in the garage and changed it out. Have not had a problem since!
    2000 Daytona 500 - Tog Headers with catted Downpipe, EGR Delete, 180* Thermostat, Solid engine mount, Poly tranny mount/Dogbones, K&N CAI with a custom tune.
  12. #12 Re: bout to give up
    hangover park IL
    many of those similar issues occur on cars where the cam/crank/ICM harness is improperly routed and it gets dragged into the AC clutch where it intermittently shorts to ground through the pulley bearing...ive seen dozens similar...
    ~James~ Psychotic Gearhead
  13. #13 Re: bout to give up
    Feb 2010
    Knoxville, TN
    +1 on the ignition module.
  14. #14 Re: bout to give up
    Jul 2013
    Sheffield,Pa
    thanks everyone for your ideas...I've ordered a MAF, IAC and TPS for now ( since these seem to be the cheap ideas first)..they should be here Thurs. I'll install each one at a time and road test before I install the next one.. If all fails, at least I know they'll all be new. Then I'll try the Ignition Control Module...If thats not it, then time to bite the bullet and take it to the dealer...but first, I'll have to re-mortage the house..
  15. #15 Re: bout to give up
    Jul 2013
    Sheffield,Pa
    well, it wasn't the Idle Air Control valve.. waiting for the other parts
  16. #16 Re: bout to give up
    Aug 2013
    arlington, tx
  17. #17 Re: bout to give up
    Enfield, CT
    try cleaning the ignition control module contact points and the contacts on the plate that holds the ICM
  18. #18 Re: bout to give up
    Jul 2013
    Sheffield,Pa
    No Luckyg, your issue is different.. And High octane, I cleaned the top of the plate real good before installing the new coils..The other parts are supposed to be here today. If they don't clear up the problem, I'll get a new Ignition control module. After that, I'm done. To the dealer it goes. Hate throwing money at it and it not being the problem. Glad they're all kinda cheap. At least the parts will be new and wont have to worry about them for awhile
  19. #19 Re: bout to give up
    Aug 2013
    arlington, tx
    Well my issue was a progression of my MAP sensor failing more and more until I bit the bullet and took it to the dealership to get scanned. Might be something worth looking into.
  20. #20 Re: bout to give up
    Jul 2013
    Sheffield,Pa
    well to the dealer it goes...now its having a hard time starting..
    1, new gas cap
    2. new idle air control valve
    3. new MAF sensor
    4. new coils
    5. new plugs and wires
    6. new TPS
    Cleaned the ignition control module, rechecked the plugs...now throwing an evac code. Time for the dealer to smoke it. I give up trying to find the problem...
    The MAF sensor did clear up the part where it cuts out...service engine light on...Damn car is really starting to piss me off. Never had this problem on my old car, 98 Buick Reagl GS...the Grand Prix is the kids car...guess this is why Buick is still selling cars and Pontiac has gone by the wayside...too bad too, I REALLY LIKE this Grand Prix
  1. Oil Oil Oil rant bout it....
    By TorqueAutoMotiv in forum The Rant Forum
    Last Post: 01-18-2010, 09:43 AM
  2. How bout Accord wheels? lol
    By Agentlongwood in forum Tires & Wheels
    Last Post: 11-18-2009, 01:20 PM
  3. thinking bout lowering my gt
    By eyeless in forum Brakes/Suspension/Chassis
    Last Post: 09-11-2009, 03:20 AM
  4. How bout peeps from Northern GA?
    By hercman in forum Southeast
    Last Post: 02-06-2009, 01:52 AM
  5. How Bout Dem Cowboys
    By SLO-6 in forum The Rant Forum
    Last Post: 10-07-2008, 09:34 PM
