Thread: Cam Lope vs timing chain
Results 1 to 20 of 28
  1. #1 Cam Lope vs timing chain
    GT Level Member jrb1027's Avatar
    Jun 2013
    brookville,IN
    Hi I have a question about xp cam, I want to be able to hear the lope of the cam so I will need to set the idle low. Is this hard on the timeing chain?
  2. #2 Re: Cam Lope vs timing chain
  3. #3 Re: Cam Lope vs timing chain
    Buffalo
    I have my idle set lower in Park and Neutral. So when it's in drive (98% of the time) it's not as bad on the chain
  4. #4 Re: Cam Lope vs timing chain
    Dec 2013
    ohio
    The tuner at intense said "lope is not recommended" You can call and talk to them. They did me right.
  5. #5 Re: Cam Lope vs timing chain
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    But. Low idle, for maximum noise.
    INB4 BLUEGUYYY
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  6. #6 Re: Cam Lope vs timing chain
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Quote Originally Posted by WhiteLightningGTP View Post
    INB4 BLUEGUYYY
    And break all the things
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  7. #7 Re: Cam Lope vs timing chain
    Buffalo
    Which is why I have mine set the way I do
  8. #8 Re: Cam Lope vs timing chain
    Jun 2013
    brookville,IN
    INB4 BLUEGUYYY
    Yea this is pretty much why I made this thread I thought this is why blueguy broke his timing chain and gear
  9. #9 Re: Cam Lope vs timing chain
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Because he had a massive cam.
    He ran the Original Thrasher and set his idle at like 650. So much thump.
  10. #10 Re: Cam Lope vs timing chain
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    If you want lope,do the double roller.Just remember to machine the correct camfer into the crank sprocket.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  11. #11 Re: Cam Lope vs timing chain
    Jun 2013
    brookville,IN
    Quote Originally Posted by goldgp View Post
    I can deal with no lope so i can keep stock chain I dont wana deal with the double roller
  12. #12 Re: Cam Lope vs timing chain
    redneck tennessee
    I don't blame you.If your not running hella stiff springs, then its not needed anyway.
  13. #13 Re: Cam Lope vs timing chain
    Buffalo
    Xp cam / 105 springs. Haven't seen a failed chain post yet
  14. #14 Re: Cam Lope vs timing chain
    Jun 2013
    brookville,IN
    Well looks like im going with a double roller anyways its comeing with the cam and heads. So you guys think i will be ok with a little lope, its an xp cam and 90#springs
  15. #15 Re: Cam Lope vs timing chain
    Buffalo
    Lol xp , 90lb springs and a double roller? If you're wasting money can I have some ?
  16. #16 Re: Cam Lope vs timing chain
    Jun 2013
    brookville,IN
    I know I know....but its used and that's what it comes with really good price too
  17. #17 Re: Cam Lope vs timing chain
    Banned
    CT
    You should have 130s with an XP... I ran 105s forever and thought they worked just fine.
    Until I saw the dyno sheet when I finally put the 140s in.
  18. #18 Re: Cam Lope vs timing chain
    Jun 2013
    brookville,IN
    Yes I know I'm gonna buy some if I can find a used set
  19. #19 Re: Cam Lope vs timing chain
    I'm running a stock chain and dampener on an s1x with yella tella 1.8 rr and 130# springs.
  20. #20 Re: Cam Lope vs timing chain
    redneck tennessee
    But how long will it last...
  1. double timing vs stock timing chain
    By Dam20735 in forum General Tech Discussion
    Last Post: 05-24-2013, 12:53 PM
  2. 3.1 timing chain
    By bybeecl in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-01-2011, 11:56 AM
  3. timing chain
    By pure in forum General Tech Discussion
    Last Post: 08-16-2009, 02:00 PM
  4. Which timing chain to get.
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 09:01 AM
  5. Which timing chain?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 04:49 PM
