Thread: Top Swap
Results 1 to 12 of 12
  1. #1 Top Swap
    Jul 2014
    MN
    So I wanna do a top swap on my 03 grand prix gt. Instead of buying a whole kit for $1300, could I just buy a junky second grand prix gtp for $700 and take the supercharger and all other needed parts from there and put it right into my 03 gt? Or would that be a bad idea considering that junk car would have like 200K miles on it? I want to keep driving my 03 for MANY years to come and don't wanna have to spend any more money than I have to. It currently has 76K miles on it. Short term I'm thinking buy the junk second car, but long term, I don't know. Your thoughts?
  2. #2 Re: Top Swap
    Aug 2013
    McDonald PA
    There's a series 3 top swap on here for cheap
  3. #3 Re: Top Swap
    Jul 2014
    MN
    Do you have the link?
  4. #4 Re: Top Swap
    Feb 2013
    37.295091, -121.930053
    he said it on here so go look in the for sell section
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: Top Swap
    St. Louis
    Well, if you get that $700 car and use the parts, you still need coolant, headgaskets, new head bolts, coolant elbows, wideband 02 sensor, a way to scan for KR, and a custom tune. The tune alone could run you 2-$300. Add in the other parts and you are right back to 1300 real quick. The old addage of Fast, Cheap Reliable- Pick 2 applies here.
  6. #6 Re: Top Swap
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by Youngster View Post
    For $700+ consider finding a GTP/GS/SS that was wrecked and just do a full motor and trans swap. Much less tearing apart involved plus that way you get the HD trans, taller gears, and better diff.
    http://dayton.craigslist.org/cto/4587121953.html
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  7. #7 Re: Top Swap
    Aug 2013
    McDonald PA
    I can't link you via tapatalk. If I find it. I'll post it in here
  8. #8 Re: Top Swap
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    You can copy the URL from tapatalk and paste it.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  9. #9 Re: Top Swap
    Dec 2012
    troll land
    Id say stick with the 3.29 geared tranny
  10. #10 Re: Top Swap
    GT Level Member MCbatt's Avatar
    Oct 2013
    MARYLAND
    If it's an 03 gt isn't it a 2.93 geared trans? I thought only the 97 gt's with the 4t60 and the comp g's were 3.29's
    Courage is fear hanging on a moment longer.
    -Thomas Fuller-
  11. #11 Re: Top Swap
    Dec 2012
    troll land
    All l36s were 3.29s gps.
  12. #12 Re: Top Swap
    Florida
    also if you have an 03 the trans and pcm are diff then other years. so you would need run 03 gtp/gt code. unless you swapped everything... topswap will be in the 1000-1300 area. if you topswap i recommend doing headers while in there. much easier when the rear head is off the engine. plus topswaps need the extra flow to handle the stock pulley with high compression. you may even consider rockers or another mod.
  1. Tuning Issues, 04 GT (L32 Swap / Gear Swap)
    By RivMan in forum PCM Tuning
    Last Post: 09-12-2013, 08:37 PM
  2. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  3. l67 swap, trans swap
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 07:11 AM
  4. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  5. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
