When you say .. you tried putting it in second gear, did you manually select it?
Try this.. put the car in D .. does it slip or refuse to move?
If you then put it in 2 or 1 .. does it slip and move poorly until you are up to speed?
If those two seem right.. your forward band most likely broke.
