Thread: Need Help. Possible transmission problem
Results 1 to 13 of 13
  1. #1 Need Help. Possible transmission problem
    SE Level Member ndaeger's Avatar
    Apr 2014
    ohio
    My names Nick and I drive a 2007 Grand Prix GXP.
    so today I went out to give my car a bath when the car started to ding and shut off everything like traction control, stability control and so on.. it's done this before so I let it idle for a few min and everything went back to normal. Well I wanted to make sure everything else was alright so I went to take a drive down the road and and soon as I tried putting it in second gear it hopped stuttered and cluncked until it barely made it. So I tried third and did the same thing. I have no idea what's wrong because it was completely fine yesterday and now it will barely make it 1/4 mile down the road. If anyone has any suggestions as to what I could do or what is wrong I would greatly appreciate it!
    Sent from my SM-G900V using Tapatalk
  2. #2 Re: Need Help. Possible transmission problem
    Mar 2014
    PA
    How many miles on the car/tranny? GXP trannys have a very high failure rate. From what you describe your tranny is likely toast. Then again it could be something else, but busted tranny is my first guess. If you don't have the tools/knowledge then your only answer will come from taking it to a shop, obviously.
  3. #3 Re: Need Help. Possible transmission problem
    Apr 2014
    ohio
    Around 94000... but well I took it out again later and it worked fine it seemed like... this was after we unhooked the battery
  4. #4 Re: Need Help. Possible transmission problem
    Mar 2014
    PA
    Quote Originally Posted by ndaeger View Post
    Then it could be PCM related.
  5. #5 Re: Need Help. Possible transmission problem
    When you say .. you tried putting it in second gear, did you manually select it?
    Try this.. put the car in D .. does it slip or refuse to move?
    If you then put it in 2 or 1 .. does it slip and move poorly until you are up to speed?
    If those two seem right.. your forward band most likely broke.
  6. #6 Re: Need Help. Possible transmission problem
    Apr 2014
    ohio
    Quote Originally Posted by EB0286 View Post
    Alright I did some research and hat you said seems like it could be the problems... but i was also wonder do you think it could be the ECM or the TCM? I read that those could also be the issue...
  7. #7 Re: Need Help. Possible transmission problem
    Apr 2014
    ohio
    Alright so when I drove it I was in manual and went from 1st to 2nd to 3rd and it messed up both times. By that I mean it seemed like it wanted to stall and just hopped and rocked until it finally got going a bit. I also tried it in drive too on the way back home and it did move and still messed up.. so I don't believe it was from using manual. And what is a forward band?.. sorry I'm pretty lost about this whole thing right now..
  8. #8 Re: Need Help. Possible transmission problem
    Explain "messed up".. I'm sitting at a computer very far away and really can't quite get my telepathy working enough to understand the symptoms from your description.
    Hopped, rocked, stalled.. it's not quite making sense with messed up to me. Please try to be very descriptive as to when it does what and how it seems to do it.
    I won't guess on pcm or tcm because typically they aren't an issue. There are many more things that can be the issue before we start talking about either of those.
  9. #9 Re: Need Help. Possible transmission problem
    Apr 2014
    ohio
    Alright by messed up I meant as it tried to shift to second gear it it seemed to idle down low then slow down then continued to rock, hop and clunk until it made it into gear.. and even then it seemed like it wasn't at full power. That any better?.. it's tough to explain hah
  10. #10 Re: Need Help. Possible transmission problem
    May 2012
    Where winter never ends
    The forward band is a component inside the transmission. Looks like this: $(KGrHqJ,!qgE-zCs0okbBPubE0vI3!~~60_35.JPG
    and what they do:
    http://auto.howstuffworks.com/automa...smission10.htm
    2000 Regal - Winter Beater
  11. #11 Re: Need Help. Possible transmission problem
    Apr 2014
    ohio
    Well just got back from the transmission shop and they said it had something to do with the clutch packs ... so it's a mechanical issue and the reason my car was jerking was because the computer was trying to correct for the issue in the transmission making it shift hard or jump around. I guess now I ask is there anything I should look out for when purchasing and installing a rebuilt tranny?
  12. #12 Re: Need Help. Possible transmission problem
    Apr 2013
    White Lake
    Why not throw some lucas trans fix in and see if it still continues? YES I know it doesnt not "fix" but it could put a band aid on your trans for a lil bit until it finally goes then get it rebuilt!
  13. #13 Re: Need Help. Possible transmission problem
    Apr 2014
    ohio
    Quote Originally Posted by CyxRyan View Post
    See my transmission is wrong fine now... it will sporadically act up... I feel like it's an electrical issue but transmission guy says is a bad tranny...
  1. Transmission problem? Help?
    By jman44 in forum Introductions/Noob Questions
    Last Post: 10-13-2014, 07:09 AM
  2. Transmission problem??
    By brenglen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2013, 10:23 PM
  3. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  4. Transmission Problem
    By cbeach in forum Introductions/Noob Questions
    Last Post: 12-30-2010, 08:23 PM
  5. Transmission problem?
    By The LoKi in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 12-19-2010, 02:43 PM
