Thread: GTP runs for a few seconds then dies.... battery light on
Results 1 to 8 of 8
  1. #1 GTP runs for a few seconds then dies.... battery light on
    Nov 2011
    Omaha, NE
    Just bought a 2000 gtp with 87k on it and now it's acting up. I parked it in my friends driveway 5 minutes ago and realized the car was parked too close to his mom's car so I decided to pop it in neutral to roll it back. Well I rolled back maybe 3 inches when I hit the brick my friend put behind my tire (we were going to jack the car up). So while the car was in neutral I started the car and it started fine and then instantly ran really bad and died within three seconds of starting it. So I tried to restart it in park and same situation. Every time after it does the battery light will come on. Fuel pump primes strong but I doubt it has anything to do with that.
    Could it be the maf?
  2. #2 Re: GTP runs for a few seconds then dies.... battery light on
    Nov 2011
    Omaha, NE
    Tried unplugging maf and the problem still persists
  3. #3 Re: GTP runs for a few seconds then dies.... battery light on
    Prolly the fuel pump resistor.
    Try bending the tab on the relay to put the pump in high speed mode, there are pictures that show the relay and which tab to bend.
  4. #4 Re: GTP runs for a few seconds then dies.... battery light on
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  5. #5 Re: GTP runs for a few seconds then dies.... battery light on
    Nov 2011
    Omaha, NE
    Alright so is that just a temp fix until the pump burns out from running on high full time?
  6. #6 Re: GTP runs for a few seconds then dies.... battery light on
    Nov 2011
    Omaha, NE
    I'll try it out when the car is back on the ground again
  7. #7 Re: GTP runs for a few seconds then dies.... battery light on
    You could run it in high mode for a long time, lots of people have done it. If it has fuel to cool the pump it doesnt make it burn out quicker, but older pumps can just die out.
  8. #8 Re: GTP runs for a few seconds then dies.... battery light on
    Nov 2011
    Omaha, NE
    Makes sense. Well its running again so thanks for the help
  1. P0453 runs for a couple seconds then dies
    By aeidian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2014, 04:06 PM
  2. 00 GTP struggles to run after starting,dies after a few seconds.
    By iowagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2014, 01:31 PM
  3. not your typical "runs for 3 seconds and dies" thread.
    By darkhorizon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2012, 09:35 AM
  4. Cars starts then within seconds DIES!
    By MistyChameleon in forum General Tech Discussion
    Last Post: 07-15-2011, 03:34 PM
  5. Idles for 5 seconds then dies
    By 00grandprix in forum Engine
    Last Post: 04-30-2011, 04:32 PM
