Thread: Driver side windshield wiper swings out past the edge of windshield
Results 1 to 10 of 10
  1. #1 Driver side windshield wiper swings out past the edge of windshield
    Apr 2014
    SW Indiana
    The wiper doesn't stop but continues past the edge of the windshield. Is this a bad wiper transmission? -JCVV
  2. #2 Re: Driver side windshield wiper swings out past the edge of windshield
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    did you recently change wiper arms ?
  3. #3 Re: Driver side windshield wiper swings out past the edge of windshield
    Apr 2014
    SW Indiana
    I did not recently change wiper arms.
  4. #4 Re: Driver side windshield wiper swings out past the edge of windshield
    Donating User Odi's Avatar
    Chicago South Suburbs
  5. #5 Re: Driver side windshield wiper swings out past the edge of windshield
    St. Louis
    Leave the wipers off, remove the cover to the nut that holds the arm on the shaft and move arm to the rest position, then tighten the arm back down. Most likely just slipped. I carry a 13mm wrench just for this issue, lol...
  6. #6 Re: Driver side windshield wiper swings out past the edge of windshield
    Apr 2014
    SW Indiana
    Thanks for the video Odi and the advice FordMan77. Will try that tonight (if it stops pouring :-) )
  7. #7 Re: Driver side windshield wiper swings out past the edge of windshield
    GT Level Member MCbatt's Avatar
    Oct 2013
    MARYLAND
    Did you get this fixed? Happened to me a couple weeks ago and all I did was take the cover off the wiper arm and tighten the nut, then it worked just fine again.
    Courage is fear hanging on a moment longer.
    -Thomas Fuller-
  8. #8 Re: Driver side windshield wiper swings out past the edge of windshield
    Apr 2014
    SW Indiana
    I found out after I went to work on the car (its my son's car) that the wipers park in the straight up position also. I replaced the transmission this morning, got it back together, without the wiper arms on I did a test run to make sure they worked, and it looks like if I put the wiper arms back on they will be parked in the upright position still. What do I do now??
  9. #9 Re: Driver side windshield wiper swings out past the edge of windshield
  10. #10 Re: Driver side windshield wiper swings out past the edge of windshield
    Apr 2014
    SW Indiana
    ok. I think I got it! The finger deal wasn't hitting the tab. I took the transmission linkage off the motor shaft and repositioned it so the finger would rotate all the way past the metal tab and it now catches every time. My last issue is the driver side shaft that hold the wiper arm is very wobbly. I will probably end up replacing that end piece on the transmission with the same part off the transmission I took off. The wipers now work at least.
    Thanks again everyone.
  1. Weak Driver Side Windshield Washer Spray
    By robinsone in forum General Tech Discussion
    Last Post: 03-03-2014, 08:50 PM
  2. windshield wiper
    By backinblackgtp in forum General Tech Discussion
    Last Post: 12-30-2011, 11:58 PM
  3. Driver's Side Windshield Wiper Stopped Working.
    By Chaotic94 in forum General Tech Discussion
    Last Post: 02-27-2011, 05:29 PM
  4. Windshield Wiper Help
    By Liquifire in forum General Tech Discussion
    Last Post: 01-17-2010, 03:19 PM
  5. windshield wiper help
    By maybe_memories in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2008, 02:48 PM
