Thread: Weak Driver Side Windshield Washer Spray
Results 1 to 5 of 5
  1. #1 Weak Driver Side Windshield Washer Spray
    May 2012
    Bloomington, IN
    So all of a sudden I've lost the pressure or spray coming from the driver side windshield washer nozzle. I thought it was a bad pump, so I replaced it and used compressed air to blow any clogs or obstructions out of all the tubing. After doing all this, it still doesn't seem like the driver side has enough pressure. Washer fluid does come out, but its more of a dribble then a spray. The passenger side is unaffected, good spray and reach. I've found things pointing to a bad ground to the pump. I want to see if anyone's had experience and if I should check the ground, assuming a bad ground would reduce the pump efficiency and result in good pressure to the passenger which is closest to the pump, but bad pressure to the driver side. Let me know if anyone's had any similar experience, thanks.
  2. #2 Re: Weak Driver Side Windshield Washer Spray
    the spray tips are clogged up. find a new set. they may be part of the wiper arm, not 100% sure on a GP.
  3. #3 Re: Weak Driver Side Windshield Washer Spray
    St. Louis
    I know for a fact that the lower spray nozzle on the arm is replaceable. It just clips onto the metal arm. I need one for my drivers side currently and just had it off 2 days ago to try and fix it, lol... As far as the top one goes, not sure if it's replaceable or not. Never really looked. Of course this is assuming you have a 97-03 GP.
  4. #4 Re: Weak Driver Side Windshield Washer Spray
    Nov 2012
    Madison
    Try a small sewing needle in the orifice to unplug it, be careful not to bore it out.
    Mine did the same thing and as soon as I ordered a new arm it miraculously started working perfect.
  5. #5 Re: Weak Driver Side Windshield Washer Spray
    Dec 2012
    Where 4T65E's were born
    I've unclogged those things numerous times at work, if you sprayed compressed air in the normal direction fluid normally goes, it won't do anything. You need to put the tip of the blow bun into the spray nozzle and spray backwards, I prefer to use water from a garden hose because air alone may not carry all of the contaminants out of the line. They almost never clog unless there's crap in the washer fluid bottle.
    Sold.
  1. 98 GTP windshield washer
    By paddenjoseph in forum Brakes/Suspension/Chassis
    Last Post: 10-09-2013, 10:12 AM
  2. windshield wiper spray problem
    By bocou92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2013, 04:16 PM
  3. Windshield Washer not working
    By trailshredder in forum General Tech Discussion
    Last Post: 01-30-2013, 04:48 PM
  4. Driver's Side Windshield Wiper Stopped Working.
    By Chaotic94 in forum General Tech Discussion
    Last Post: 02-27-2011, 05:29 PM
  5. Washer fluid wont spray..
    By skubasteve! in forum General Tech Discussion
    Last Post: 12-05-2008, 06:57 PM
