Thread: Need Help with P0106 and P0420 codes!!
Results 1 to 20 of 32
  1. #1 Need Help with P0106 and P0420 codes!!
    Jackson, Mississippi
    Hello everyone. I took my 2008 Pontiac GP 3800 to a GM service dept to have the P0106 and P0420 codes checked out and they claim I need a MAP sensor $93.00, Map sensor system cleaning $200.94, a EGR system cleaning $200.94 and a Fuel injector cleaning $139.00 which will cost over $700 bucks! I think they are trying to pull one over on me. Has anyone ever had problems with these codes?? Please let me know what you think... Your help would be most appreciated...
  2. #2 Re: Need Help with P0106 and P0420 codes!!
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    you can get that $93 MAP sensor off ebay for $13. bad o2 sensors can give a p0420 code. I would change both o2 sensors and the MAP sensor, you can get all 3 for less than $60 on ebay. . As for cleaning everything run some SeaFoam thru it and start using Lucas gas treatment.
  3. #3 Re: Need Help with P0106 and P0420 codes!!
    I wouldn't get any of that stuff on ebay if it was my car. Get the stuff from Rockauto or Partsgeek. And don't ever take your car to a dealer, they will charge you for everything and anything they can.
  4. #4 Re: Need Help with P0106 and P0420 codes!!
    Quote Originally Posted by Slick2500 View Post
    Thanks. Yea they must think I was born yesterday. I wont be going back to a dealership ever again thats for sure.
  5. #5 Re: Need Help with P0106 and P0420 codes!!
    What is code 106?
  6. #6 Re: Need Help with P0106 and P0420 codes!!
    Its code P 0106
  7. #7 Re: Need Help with P0106 and P0420 codes!!
    P0106 - MAP/Barometric Pressure Circuit Range/Performance Problem
    Read more at: http://www.obd-codes.com/p0106
    Copyright © OBD-Codes.com
  8. #8 Re: Need Help with P0106 and P0420 codes!!
    Thanks for the info.
  9. #9 Re: Need Help with P0106 and P0420 codes!!
    Slipperywhenwet2500, I was looking for him to do the work.. Nice job though. Hmmm
  10. #10 Re: Need Help with P0106 and P0420 codes!!
    Yeah I can Google like a boss.
  11. #11 Re: Need Help with P0106 and P0420 codes!!
    Jul 2010
    Coquitlam,BC,Canada
    They told you that you need to replace AND clean the MAP sensor? That's a good one.
    When I have P0420 it was a bad cat. I changed it right meow and all was good.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  12. #12 Re: Need Help with P0106 and P0420 codes!!
    Quote Originally Posted by Bronco Boy View Post
    What problems was your car giving you when you found out it was the cat?
  13. #13 Re: Need Help with P0106 and P0420 codes!!
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by mcdavidhome View Post
    The PO of the car had a very small cat on it, and a burnt out CEL bulb.
    Here is some more info..... http://chrisb.users.superford.org/Gr...Converter.html
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  14. #14 Re: Need Help with P0106 and P0420 codes!!
    ok thanks
  15. #15 Re: Need Help with P0106 and P0420 codes!!
    I am considering having my cat removed permanently. Do you think the check engine light would continue to stay on after I cut it out and replace with a straight pipe
  16. #16 Re: Need Help with P0106 and P0420 codes!!
    Aug 2013
    McDonald PA
    Yep till you get it tuned out
  17. #17 Re: Need Help with P0106 and P0420 codes!!
    Ok forgive my ignorance but what does getting it tuned out mean exactly.
  18. #18 Re: Need Help with P0106 and P0420 codes!!
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Sounds like you need a map sensor, Costs about 40$ from amazon and is a 5 min job to replace. The other code could be one of a few things, Could be a bad rear o2, could be a bad front o2, could be a bad cat, could be a aftermarket cat not doing enough as far as your engine computer is concerned. Personally? I would replace the front o2 if it is more then 60k miles or 5 years old and then do the non fouler trick on the rear o2. You don't need a o2 sensor to tell you when your cat is going bad. Trust me you will know because your car will not go over X mph. Also ignore all of that cleaning bull****.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  19. #19 Re: Need Help with P0106 and P0420 codes!!
    Quote Originally Posted by frosty View Post
    Sounds like you need a map sensor, Costs about 40$ from amazon and is a 5 min job to replace. The other code could be one of a few things, Could be a badfor ave rear o2, could be a bad front o2, could be a bad cat, could be a aftermarket cat not doing enough as far as your engine computer is concerned. Personally? I would replace the front o2 if it is more then 60k miles or 5 years old and then do the non fouler trick on the rear o2. You don't need a o2 sensor to tell you when your cat is going bad. Trust me you will know because your car will not go over X mph. Also ignore all of that cleaning bull****.
    Thanks for the info. The car only has 52,000 miles on it so i will start first with replacing the Map sensor and see if the code clears. My car is driving fine and my gas mileage is still the same
  20. #20 Re: Need Help with P0106 and P0420 codes!!
    Thanks
  1. p0420
    By sirricealot in forum 5.3L V8 (LS4)
    Last Post: 04-25-2013, 10:20 AM
  2. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  3. p0420
    By chickenfried in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2010, 04:26 PM
  4. p0420 codes... common??
    By dcwright02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2010, 12:44 AM
  5. P0172 and P0420 Codes
    By machinegunsquid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2010, 10:21 PM
