Thread: Need Help with P0106 and P0420 codes!!
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21 Re: Need Help with P0106 and P0420 codes!!
    Jackson, Mississippi
    Quote Originally Posted by genki View Post
    Clean the old map and check the cable first before buying a new one. There's guide on safe cleaning but dirt or dead bug stuck on the map can throw bad map. Check the intake air filter if it was dirty map.
    Ok but are you referring to the MAP sensor or the Mass Air flow sensor?
  2. #22 Re: Need Help with P0106 and P0420 codes!!
    Quote Originally Posted by Bronco Boy View Post
    They told you that you need to replace AND clean the MAP sensor? That's a good one.
    When I have P0420 it was a bad cat. I changed it right meow and all was good.
    What problems was your car giving you when you found out it was the cat?
  3. #23 Re: Need Help with P0106 and P0420 codes!!
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by mcdavidhome View Post
    The PO of the car had a very small cat on it, and a burnt out CEL bulb.
    Here is some more info..... http://chrisb.users.superford.org/Gr...Converter.html
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #24 Re: Need Help with P0106 and P0420 codes!!
    Aug 2013
    arlington, tx
    What problems was your car giving you other than the check engine light staying on? Actually I am not having any mechanical problems right now my car still drives fine.
    http://www.grandprixforums.net/threa...alling-Problem
    ^^This
  5. #25 Re: Need Help with P0106 and P0420 codes!!
    ok thanks
  6. #26 Re: Need Help with P0106 and P0420 codes!!
    I am considering having my cat removed permanently. Do you think the check engine light would continue to stay on after I cut it out and replace with a straight pipe
  7. #27 Re: Need Help with P0106 and P0420 codes!!
    Aug 2013
    McDonald PA
    Yep till you get it tuned out
  8. #28 Re: Need Help with P0106 and P0420 codes!!
    Ok forgive my ignorance but what does getting it tuned out mean exactly.
  9. #29 Re: Need Help with P0106 and P0420 codes!!
    Quote Originally Posted by frosty View Post
    Sounds like you need a map sensor, Costs about 40$ from amazon and is a 5 min job to replace. The other code could be one of a few things, Could be a bad rear o2, could be a bad front o2, could be a bad cat, could be a aftermarket cat not doing enough as far as your engine computer is concerned. Personally? I would replace the front o2 if it is more then 60k miles or 5 years old and then do the non fouler trick on the rear o2. You don't need a o2 sensor to tell you when your cat is going bad. Trust me you will know because your car will not go over X mph. Also ignore all of that cleaning bull****.
    I replaced the MAP sensor and still the same problem exists. I am pretty sure its the CAT now. Whenever I throttle very hard trying to pass someone the car stalls outand looses power until I let up off the throttle again.
  10. #30 Re: Need Help with P0106 and P0420 codes!!
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Having someone with turning software have the code set not to report.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  11. #31 Re: Need Help with P0106 and P0420 codes!!
    Apr 2012
    Dayton, OH
    Having someone with turning software have the code set not to report. So your SES light wont come on for whatever code for the car.
    Edit: oops didnt mean to double post just edit my first one lol
    2012 F150 STX
  12. #32 Re: Need Help with P0106 and P0420 codes!!
    Ok thanks for the info
  1. p0420
    By sirricealot in forum 5.3L V8 (LS4)
    Last Post: 04-25-2013, 10:20 AM
  2. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  3. p0420
    By chickenfried in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2010, 04:26 PM
  4. p0420 codes... common??
    By dcwright02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2010, 12:44 AM
  5. P0172 and P0420 Codes
    By machinegunsquid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2010, 10:21 PM
