Thread: Car makes noise when turning right
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
  1. #1 Car makes noise when turning right
    Aug 2012
    Tukwila, Washington, United States
    Yesterday my car started to make grinding noise like its touching some metal when I turn.
    It's worse when I have more speed with the turn, when there's weight dropped to the left side I guess.
    So if I'm turning slowly there's no sound.
    I tried to look around but I didn't notice anything wrong.
    Any hints?
    Grand Prix gt 1999 v6 3.8L coupe.
  2. #2 Re: Car makes noise when turning right
    You might need some new brakes, or maybe the dust shield is rubbing on the rotor.
    Or a wheel bearing went, hard to say without taking the tires off.
  3. #3 Re: Car makes noise when turning right
    Jack it up and pop a tire off and see what's going on with it.
  4. #4 Re: Car makes noise when turning right
    Aug 2012
    I'm on it right now. I took both front wheels out. Nothing looks suspicious.
    To be honest I don't think it has to do with the wheel.
    It sounds like a fan motor touching metal. And it's not the fans.
    It happens when I accelerate and turning right on speed when the engine weight drops to the left back.
    I hope it has nothing to do with tras plats going bad.
  5. #5 Car makes noise when turning right
    Aug 2012
    Here's a video
    It feels around the gas pedal and when I hit the gas and turn it makes the noise.
    http://youtu.be/kJMO9aXFO3U
  6. #6 Re: Car makes noise when turning right
    With the wheel on shake it and see if it has any wiggle to it
  7. #7 Re: Car makes noise when turning right
    Aug 2012
    I took the wheel out again.
    Could it be the metal shield causing this?
    I'm really desperate.
    I don't have a budget for car fixes right now.
  8. #8 Re: Car makes noise when turning right
    Maybe a dust sheild rubbing, put the rotor back on and spin it by hand and see if it's touching.
    I'd check the rear brakes out aswell, could be from there.
  9. #9 Re: Car makes noise when turning right
    Aug 2012
    I can hear it from the left from when turning and on load.
    I'd try move it but it's the front and it won't move.
  10. #10 Re: Car makes noise when turning right
    Dec 2012
    Where 4T65E's were born
    Have you jacked the front up, (put the parking brake on) and put it in drive and steered yet?
    Sold.
  11. #11 Re: Car makes noise when turning right
    St. Louis
    You have to put it in neutral to spin it with it off the ground.
    When the tire was on it, did you push/pull on the tire at the 12 and 6 o'clock position? If there is play then it's likely a wheel bearing.
  12. #12 Re: Car makes noise when turning right
    Jan 2014
    AR
    Under the car, remove the starter inspection plate and see if you can move the starter gear back and forth with your finger. I had one go bad on a 99 L36, and when you turn in one direction, inertia flings the starter gear against the flexplate. It bounces back and forth and makes helluva racket that draws lots of attention! That would be the return spring getting lazy on the starter drive, so replacing the whole thing is the fix. Do it before the starter ring on the flexplate gets all chipped up, if you find thats the problem.
  13. #13 Re: Car makes noise when turning right
    Aug 2012
    Quote Originally Posted by idrivejunk View Post
    I have the feeling it's something like this.
    Cause I took the wheel and caliper twice out. There's nothing there.
    And the sound stays the same even if I'm on 60 and turn to a right lane.
    And feels under my feet
    That means the speed of whatever is rubbing there is not from the wheel.
    It's only increasing with rpm and load on the left side.
    So what to look for in simple words?
  14. #14 Re: Car makes noise when turning right
    Jan 2014
    AR
    "Under the car, remove the starter inspection plate and see if you can move the starter gear back and forth with your finger." <<< Do that. Two probably 10mm bolts hold a plastic plate onto the engine next to the starter take that off. If you can move the starter gear back and forth with a finger, the starter is "bad" even though it probably works fine. I borrowed this pic from a google search. See the gear? If you can move that back and forth freely theres your trouble.
    Attachment 13048
  15. #15 Re: Car makes noise when turning right
    Aug 2012
    So I need a new starter if it moves.?
  16. #16 Re: Car makes noise when turning right
    Jan 2014
    AR
    Yes. If you remove the starter and can tip it side to sode and the gear slides back and forth, you need a starter. It is only supposed to move when the starter tells it. When its making the noise, the starter isn't turning but the gear is bouncing around.
  17. #17 Re: Car makes noise when turning right
    Aug 2012
    Thank you all for helping. I'll try that tomorrow. I'll let u know what's going on.
  18. #18 Re: Car makes noise when turning right
    Jan 2014
    AR
    Hope you find it. Not knowing what it is, is worse than having to fix it.
  19. #19 Re: Car makes noise when turning right
    Aug 2012
    Yes I know. Thank u.
  20. #20 Re: Car makes noise when turning right
    SE Level Member Peder's Avatar
    Sacramento, CA
    I second the starter. I had this noise for about 4 years. Checked wheels, suspension, brakes, dust shields, replaced power steering pump and even got so far as to do the rack (ended up needing a rack anyway, different story). One day leaving work, starter was bad and I got towed home. Replaced starter, no sound.
    Peder02
  1. 98 GTP - Turn wheel and brake, makes vibration in pedal and noise
    By mram10 in forum Brakes/Suspension/Chassis
    Last Post: 12-02-2012, 12:04 AM
  2. Help Shaking when accelerating and makes a squeaking noise.
    By Isidro Luna in forum Brakes/Suspension/Chassis
    Last Post: 07-22-2012, 03:09 AM
  3. Car makes humming noise when driving
    By usranger13 in forum General Tech Discussion
    Last Post: 07-15-2012, 03:53 PM
  4. Car makes odd howling noise
    By SDGTP99 in forum General Tech Discussion
    Last Post: 07-20-2011, 01:50 PM
  5. Replies: 8
    Last Post: 03-11-2010, 07:59 AM
