Thread: What automatic transmission fluid to use
Results 1 to 20 of 60
  1. #1 Re: What automatic transmission fluid to use
    Jan 2013
    United States
    $140 service that only needs to be done every 80,000 miles im not worried about. my friends VW passat 99 2.6L has to have a new timing belt every 80,000 miles that cost $1200 to have done. also a trans rebuild in my car is around $2,000 depending on how strong of a rebuld you do so if buying the best ATF i can gives me an extra 10,000 miles on the trans then to me its worth it. i got 140,000 miles on the 04 GP and if you drove it you would think it just came off the GM lot.
  2. #2 Re: What automatic transmission fluid to use
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    Quote Originally Posted by sevenhellz View Post
    Nobody said anything about you wanting to spend $140.00 on ATF they are stating they would rather save or waste the money on something else (whores, strippers, lube, butthole pleasures) whatever is may be. That is your choice. I change mine once a year maybe even twice if I get bored with the top of the line Walmart Supertech DEX vi lol . . . . Have done so on all my vehicles whatever suits you best.
    OP : Just don't forget to put a new filter on HAHAHA
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  1. transmission fluid
    By ssiebor14 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-08-2013, 10:24 AM
  2. 98 GTP Automatic Transmission Problems
    By ricksowers in forum Introductions/Noob Questions
    Last Post: 08-19-2013, 05:43 AM
  3. Transmission Fluid-
    By GTByron in forum Introductions/Noob Questions
    Last Post: 05-20-2013, 11:35 AM
  4. Automatic Transmission advise
    By Severoux in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 02-21-2011, 09:42 AM
  5. What transmission fluid for 98 gtp?
    By silverPGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-18-2010, 05:22 PM
