Thread: transmission fluid
Results 1 to 8 of 8
  1. #1 transmission fluid
    SE Level Member ssiebor14's Avatar
    May 2013
    Biglerville
    Can someone tell me what transmission fluid goes into my Pontiac grand prix se it's a 97 I'm doing a flush. I need answers Google really hasn't helped.me either. Hope you guys can
  2. #2 Re: transmission fluid
    Dexron 3, your trans dipstick also says what fluid to run.
  3. #3 Re: transmission fluid
    SWPA
    How many miles?
    Either way. I highly suggest you do NOT do a flush. Do a pan drop only.
  4. #4 Re: transmission fluid
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    Dex III
    2004 Grand Prix GTP 150,000 " The New Edition "
  5. #5 Re: transmission fluid
    May 2013
    Biglerville
    That's what I mean a pan drop
  6. #6 Re: transmission fluid
    Dec 2008
    Lawndale, CA
    Do a pan drop with dex 3. Don't forget the filter as well.
  7. #7 Re: transmission fluid
    Aug 2011
    Bucks County Pa
    Quote Originally Posted by ssiebor14 View Post
    Just unbolt the transmission pan and tilt till fluid come out on one corner.
    Drain the fluid into a large pan a little at a time.
    Remove the tranmission pan.
    Remove the transmission filter.
    Remove tranmission gasket, if original can be used again.
    Clean tranmission pan and gasket.
    Install new transmission filter.
    Install tranmission pan and gasket.
    Fill with approx 6 to 8 quarts of transmission fluid Dex III.
    Check fluid for level on tranmission dip stick while warm and running.
    You just changed approx 80% of the fluid.
    George
  8. #8 Re: transmission fluid
    Dec 2012
    Where 4T65E's were born
    Actually it's a 13 quart system, making it only 65% if you replace 8.5 quarts. I did a manual flush changing about 10 quarts, that's 77%.
    Sold.
  1. Transmission Fluid-
    By GTByron in forum Introductions/Noob Questions
    Last Post: 05-20-2013, 11:35 AM
  2. transmission fluid
    By Linebacker in forum General Tech Discussion
    Last Post: 05-17-2012, 08:25 AM
  3. transmission fluid
    By dave2002GP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2010, 09:01 PM
  4. What transmission fluid for 98 gtp?
    By silverPGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-18-2010, 05:22 PM
  5. Transmission fluid
    By ChevMan92 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2010, 07:54 PM
