Thread: What automatic transmission fluid to use
Results 21 to 40 of 60
  1. #21 Re: What automatic transmission fluid to use
    Dec 2012
    Where 4T65E's were born
    That's the stuff I used, but by Valvoline brand (dex/merc III) All 3 you posted will work though. The VI is the newer fluid and is partially synthetic which is iffy sometimes on older worn transmissions.
    Sold.
  2. #22 Re: What automatic transmission fluid to use
    Aug 2012
    Tukwila, Washington, United States
    Thanks I'll think I'll go with the autozone brand cause the valvoline is about double the price.
    Grand Prix gt 1999 v6 3.8L coupe.
  3. #23 Re: What automatic transmission fluid to use
    Dec 2012
    No the dex/merc valvoline is fairly cheap
    http://www.walmart.com/ip/Valvoline-...Fluid/15125788
    Sold.
  4. #24 Re: What automatic transmission fluid to use
    Arizona
    use dex6 its at walmart, dont skimp out on your trans. If youve maintained the fluid regularly then you have nothing to worry about, i swapped to dex6 on my GTP with 110,000 with no issues what so ever.
  5. #25 Re: What automatic transmission fluid to use
    I ran Dex 6 in my 97 at 160k miles. IIRC the Supertech Dex 3 is $11.89 a gallon.
  6. #26 Re: What automatic transmission fluid to use
    Jan 2013
    United States
    i just did the ATF in my 04 gp GT2. i put royal purple in ($13 a quart) and a acdelc filter also a new gasket. i ended up getting 8 1/4 out of the trans. i bought all 10 quarts but didnt need it. took me about 2 hours to get it all done in my driveway
  7. #27 Re: What automatic transmission fluid to use
    LOL 13 bucks a quart.
    Simple cars like simple cheap as fvck fluid, I'll save my money.
  8. #28 Re: What automatic transmission fluid to use
    Oh god $13 a quart lmao waste of money
    04 Comp G.
  9. #29 Re: What automatic transmission fluid to use
    **** that ****.
    Sent from A Galaxy Far Far Away........
  10. #30 Re: What automatic transmission fluid to use
    Aug 2012
    I paid on autozone $16 a gal. I got 2 of those.
    I finally finished changing the filter and cleaned everything.
    Took me 4 hours with like 30 bolts on the pan.
    Got some muscles working under the car.
  11. #31 Re: What automatic transmission fluid to use
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Quote Originally Posted by raverockstar View Post
    4 hours? I did mine in like 1, a drill does short work of the trans pan bolts. I just turned the torque down on it.
    2012 F150 STX
    - Gonna be a race truck
  12. #32 Re: What automatic transmission fluid to use
    Aug 2012
    My first time.
    And I cleaned the pan. Made it shiny.
  13. #33 Re: What automatic transmission fluid to use
    Jan 2013
    United States
    $140 service that only needs to be done every 80,000 miles im not worried about. my friends VW passat 99 2.6L has to have a new timing belt every 80,000 miles that cost $1200 to have done. also a trans rebuild in my car is around $2,000 depending on how strong of a rebuld you do so if buying the best ATF i can gives me an extra 10,000 miles on the trans then to me its worth it. i got 140,000 miles on the 04 GP and if you drove it you would think it just came off the GM lot.
  14. #34 Re: What automatic transmission fluid to use
    Jan 2013
    United States
  15. #35 Re: What automatic transmission fluid to use
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    Quote Originally Posted by sevenhellz View Post
    Nobody said anything about you wanting to spend $140.00 on ATF they are stating they would rather save or waste the money on something else (whores, strippers, lube, butthole pleasures) whatever is may be. That is your choice. I change mine once a year maybe even twice if I get bored with the top of the line Walmart Supertech DEX vi lol . . . . Have done so on all my vehicles whatever suits you best.
    OP : Just don't forget to put a new filter on HAHAHA
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  16. #36 Re: What automatic transmission fluid to use
    Aug 2012
    Should I be worried about that the acdelco filter is made in China?
  17. #37 Re: What automatic transmission fluid to use
    I think they all are, not 100% sure on that though.
  18. #38 Re: What automatic transmission fluid to use
    Aug 2012
    Quote Originally Posted by slick2500 View Post
    It's a china sticker on a USA
  19. #39 Re: What automatic transmission fluid to use
    Jan 2013
    United States
    not positive but i bought the acdelco and i thought it said made in usa.
  20. #40 Re: What automatic transmission fluid to use
    Arizona
    IT seriously dosent matter anymore no matte rwhat you do everything is made in ****ing china these days
  1. transmission fluid
    By ssiebor14 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-08-2013, 10:24 AM
  2. 98 GTP Automatic Transmission Problems
    By ricksowers in forum Introductions/Noob Questions
    Last Post: 08-19-2013, 05:43 AM
  3. Transmission Fluid-
    By GTByron in forum Introductions/Noob Questions
    Last Post: 05-20-2013, 11:35 AM
  4. Automatic Transmission advise
    By Severoux in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 02-21-2011, 09:42 AM
  5. What transmission fluid for 98 gtp?
    By silverPGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-18-2010, 05:22 PM
