I started my car earlier so I could run to the bank and get rent money out and when I started it "fine" it started shaking, exhaust was making a popping noise and the RPMs were at around 1500-1700. It felt like the car was not getting enough fuel and then it died. I started it again and did the same thing then the display said Reduce engine power abs and t/c disabled... I thought it was maybe because it was pretty cold last night in the negatives but my "low on fuel" never showed up on display and my gas level was right above the read line. I took my truck and got 5 gallons of gas and put some Lucas fuel injector stuff in hoping that would fix the issue but I started it again and was still running rough.. The check engine light is on but I cant read it because I lost my OBD Reader...fvsdjidsdsijsdsdiosdj FML!
