'01 GTP with 163k. Three weeks ago, during an absolutely freezing, sub-zero temperature morning, I wasn't getting heat into the cabin. A few minutes later, it overheated. So installed a new thermostat and was good to go.
But last Tuesday was another sub-zero morning, and guess what? It happened again! No heat was getting into the cabin and it overheated. So I shut it off, sitting along the road to cool down. After 5 minutes sitting there with the engine shut off, I heard a "tunk tunk tunk tunk" sound from the engine, the sound of coolant surging. Like something finally thawed out and allowed coolant to flow? I fired it back up. Miraculously I had heat again and it was no longer overheating.
So... Did I install a bad thermostat a few weeks ago, and that's why it happened again? Or is there something else I'm not realizing?
It never did this before, pretty strange. I don't want it to happen a third time. Too cold to be sitting along the road!
