Thread: 2005 GTP - CAI mod question
Results 1 to 20 of 30
  1. #1 2005 GTP - CAI mod question
    Jul 2012
    Bloomington, IL
    I was reading the post about safely modifying your 3800 engine, and they mention saving money by just "bolting" on a cone filter to the end of the MAF.
    Does anyone have more specifics on doing this? What size K&N cone filter? Are there any additional pieces that you need to get to make this work?
    Jeff
  2. #2 Re: 2005 GTP - CAI mod question
    St. Louis
    Don't go with a K&N. The oil is known to kill MAF's, even if you are careful not to over-oil it. Not sure on the size.
  3. #3 Re: 2005 GTP - CAI mod question
    Jul 2012
    Bloomington, IL
    What is the recommended air filter?
  4. #4 Re: 2005 GTP - CAI mod question
    Feb 2013
    Detroit, MI
    Just grab a spectre at autozone or order on on ebay
  5. #5 Re: 2005 GTP - CAI mod question
    Feb 2013
    Detroit, MI
    You'll need 2 couplers as we have 04+ and need to include the maf.
  6. #6 Re: 2005 GTP - CAI mod question
    Aug 2013
    McDonald PA
    What did you do with that vac line
  7. #7 Re: 2005 GTP - CAI mod question
    Feb 2013
    Detroit, MI
    Drilled a hole in the middle of the coupler between the tb and maf and plugged it in there.
  8. #8 Re: 2005 GTP - CAI mod question
    Jul 2012
    Bloomington, IL
    Nice.
    Are those 3-3/2.5 intake couplers?
    Spectre filter? And where did you get the piece from the MAF to the cone filter?
  9. #9 Re: 2005 GTP - CAI mod question
    most of use use the home depot couplers, its got a metal band and clamps arounf the rubber you see there, its 5 bucks, 3 inch iirc you take the metal part off the camps and toss it.
    or buy the expensive stuff at pep boys ricer section.
  10. #10 Re: 2005 GTP - CAI mod question
    Feb 2013
    Detroit, MI
    id go grab a filter at autozone, advanced, wherever..then I brought my filter inside Home Depot to check what fit correctly. I had a 4 inch by 9 inch k&n, then I believe the tb and maf is 3.25. I don't remember though. But the standard 3 inch couplers from Home Depot is what I got. The thing you need to worry about is the cone. So if you get a 3 inch cone you can run 3 inch straight. Mine had the flare to fit the 4 inch.
  11. #11 Re: 2005 GTP - CAI mod question
    Feb 2013
    Detroit, MI
  12. #12 Re: 2005 GTP - CAI mod question
    street pvc elbows are 3 inch on the small side, 4 inches where its fat.aka the side you would glue the next pipe into in its original purpose.
    most air filters will fit 3 or 4 inch. my spectra had a rubber ring to make it work on a 3 inch pipe if needed too. take the ring out and it fits 4 inch, same as the fat side of the elbow.
  13. #13 Re: 2005 GTP - CAI mod question
    Feb 2013
    Detroit, MI
    http://www.grandprixforums.net/showthread.php?t=33351
    This is what I was looking for. Thread has all the info you'll need
  14. #14 Re: 2005 GTP - CAI mod question
    Jul 2012
    Bloomington, IL
    Perfect! Exactly what I was looking for. The peeps on this forum rock.
  15. #15 Re: 2005 GTP - CAI mod question
    If you do get the rubber coupler from home depot or lowes, I'd snag an extra one or two just because over time the thinner rubber will dry crack and become brittle. The first one of mine lasted 1 year before it started to dry crack alot, so I replaced it.
  16. #16 Re: 2005 GTP - CAI mod question
    Some people actually drive their cars. Therefore they no rot.
    Son.
  17. #17 Re: 2005 GTP - CAI mod question
    3k a year is alot of miles.
  18. #18 Re: 2005 GTP - CAI mod question
    my first home depot coupler last 2 years or longer, then new one is much thicker now and should last longer.
  19. #19 Re: 2005 GTP - CAI mod question
    Jul 2012
    Bloomington, IL
    One more question. The link you sent me looks like it's for a pre 04+ GP?? For the 04+, we need the hole for the vac line, correct? And obviously the MAF will need to be in between as well.
  20. #20 Re: 2005 GTP - CAI mod question
    Feb 2013
    Detroit, MI
    Yup, so just look at the pictures I sent
  1. 2005 GP front bumper question
    By ThomasJ2352 in forum General Tech Discussion
    Last Post: 08-10-2010, 11:55 PM
  2. 2005 exhaust question
    By Stewtcb in forum General Tech Discussion
    Last Post: 04-19-2010, 09:42 AM
  3. 2005 GTP - I think an engine question but I don't really know! :)
    By bksmith08 in forum General Tech Discussion
    Last Post: 09-01-2009, 10:06 AM
