Thread: Topping off oil
Results 1 to 10 of 10
  1. #1 Topping off oil
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    How many people here top off their engine oil when it gets down a 1/3 to 1/2 quart or wait until the add line and add a full bottle? Thanks, it is just a lazy Sunday cleaning the house and my mind is wondering.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  2. #2 Re: Topping off oil
    mine doesn't use any oil so i don't have to worry about it.
  3. #3 Re: Topping off oil
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    +1.
  4. #4 Re: Topping off oil
    May 2012
    lebanon ohio
    Quote Originally Posted by osiris94ej View Post
    +1.
    ^me too neither one of them.
    07 base tinted windows led tails new wheels spo grills spo spoiler retrofit projectors transgo shift kit overkill tune inferno lip special edition rear lip 2.5 cat back dual exhaust
  5. #5 Re: Topping off oil
    St. Louis
    Well, to answer the OP's question, I typically would top it off when it gets about 1/2 quart low. Since the valve cover gaskets are known to leak on these cars, and GM states that loosing 1qt/3000mi is considered normal consumption I'd just top it off as needed (and then fix my leak, lol..)
  6. #6 Re: Topping off oil
    your car runs better a quart low. let it get to the 1 quart line, top it off. it takes till 3,000 miles let it go till your oil change.
    dont let it ever go lower then the add 1 qt mark, thats no good.
  7. #7 Re: Topping off oil
    +1!
    04 Comp G.
  8. #8 Re: Topping off oil
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Mine is usually about 1/2 a quart low @ 3000 miles. I personally don't add any it's not gonna hurt anything if your running a quart low as long as it doesn't get any lower than that.
    I went NA when a whore left -$300 in my bank account.
  9. #9 Re: Topping off oil
    Apr 2013
    White Lake
    Every 3,000 miles I also lose 1qt but I change my oil/filter at that time anyhow.
  10. #10 Re: Topping off oil
    Jan 2012
    Southampton MA
    Mine uses about 1 qt of Mobil 1 in 5k miles, which is my normal oil change interval.
    88 IROC 350 - 23k miles, bone stock 97 Z28 30th Anniversary - 75k miles, SLP Bolt ons
    00 SS - 11k miles, OEM SLP goodies 04 Comp G - 64k miles, stock for now...
    07 Sierra Duramax 750 lb/ft of badass 13 Charger R/T - 2k miles, bone stock, Wife's car
  1. Losing coolant IMMEDIATELY after topping off radiator!! HELP!!
    By Autoworks in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2013, 06:19 AM
