Thread: Charge System Failure
Results 1 to 5 of 5
  1. #1 Charge System Failure
    Nov 2013
    Alberta, Canada
    Hey everyone, I am new to this forum and looking for some help.
    I have a 2006 Grand Prix.
    I live in Canada and the temp right now is -20 C. I went to start my car this morning and my DIC said "Charge System Failure". The car started okay but I was pretty worried. I know zero about cars other than how to check my oil and tire pressure. I drove to Kal Tire and they ran a diagnostic and told me that the battery and alternator tested fine but that I should replace them both anyways because this "failure" will just keep happening otherwise. The car has the original battery in it so I decided to replace that just because it was time anyways. They weren't too happy with me and told me that the problem will keep happening unless I change the alternator as well.
    I haven't noticed any problems with my car up until today. No lights dimming, etc...
    Has anybody else experienced this and should I get the alternator changed or will the battery be enough?
    Thanks,
    Shannon
  2. #2 Charge System Failure
    Check both the battery and alternator either can be the culprit
    Edit: also make sure your terminals are good as well if you have a voltmeter you can also test them
    04 Comp G.
  3. #3 Re: Charge System Failure
    If the battery is bad then it won't hold a charge..if the alternator is bad then it can't charge the battery. Get it?
    04 Comp G.
  4. #4 Re: Charge System Failure
    Antioch, IL
    If your battery is dead you cant start the car.
    If your battery is dying it will turn over slower, then slower, then click click click
    If your alternator is dying your car will die when driving and your lights will be very dim
    If your alternator is dead, your car will run until your battery is drained.
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: Charge System Failure
    Feb 2013
    Woodbridge NJ
    Same thing happened to my sons '04 a few weeks ago. Had the alternator tested and told it was fine. Removed the battery to find one of the caps had been blown off. Got a warranty exchange on the battery and all was fine for 6 days. then the issue came back. Changed out the alternator and so far so good. I lean towards a sporadic voltage regulator. My guess is the vr was fine when the alternator was tested. But it would fail sometimes. That is my theory. My suggestion\n would be to test the battery when the message comes up. If low I would change the battery as you say it is the original. Six years is plenty long for a battery. If the problem persists with a new battery then suspect the alternator
    Don
  1. Charge system failure light
    By Gohan77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2013, 10:24 PM
  2. Charging System Failure
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 01-03-2013, 11:51 AM
  3. Charging System Failure Help??
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2012, 06:19 PM
  4. Charging system failure
    By Durk Diggler in forum The Rant Forum
    Last Post: 01-10-2010, 05:22 PM
  5. Charging System Failure
    By missyfisch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2009, 10:27 AM
